扫一扫,分享给好友
根据我的理解,人力资源银行(ZC706评估板中的11个)应该能够在同一个银行支持LVDS_25和LVCMOS25。
但是,我收到以下错误。 错误消息如下: [放置864]不兼容的IOB被锁定到同一个存储区11Conflicting IO标准是:IO标准1:名称= LVCMOS25,VREF = NR,VCCO = 2.50,TERM = NONE,DIR = OUTPUT,DRIVE_STR = 12锁定IOB的列表:fmc_imageon_vita_receiver_0_io_vita_spi_mosi_pin hdmi_data [23] fmc_imageon_vita_receiver_0_io_vita_spi_sclk_pin fmc_imageon_vita_receiver_0_io_vita_spi_ssel_n_pin HDMI_SPDIF fmc_imageon_vita_receiver_0_io_vita_trigger_pin [2] fmc_imageon_vita_receiver_0_io_vita_trigger_pin [1] fmc_imageon_vita_receiver_0_io_vita_trigger_pin [0] IO标准2:名称= DIFF_HSTL_II_18,VREF = NR,VCCO = 1.80,TERM = NONE,DIR = OUTPUT,DRIVE_STR = NRList的锁定IOB的:fmc_imageon_vita_receiver_0_io_vita_clockin_n_pin fmc_imageon_vita_receiver_0_io_vita_clokcin_p_pin由于VCCO不匹配,这些IO标准不兼容。 在UCF中分配以下I / O: NET fmc_imageon_vita_receiver_0_io_vita_clockin_p_pin LOC =“AE22”; #CAM_CLK_PLL - FMC2-D17(LA13_P)NET fmc_imageon_vita_receiver_0_io_vita_clockin_n_pin LOC =“AF22”; #CAM_CLK_PLL - FMC2-D17(LA13_P)NET“fmc_imageon_vita_receiver_0_io_vita_clockin_p_pin”IOSTANDARD =“LVDS_25”| DIFF_TERM = TRUE; NET“fmc_imageon_vita_receiver_0_io_vita_clockin_n_pin”IOSTANDARD =“LVDS_25”| DIFF_TERM = TRUE; NET fmc_imageon_vita_receiver_0_io_vita_spi_sclk_pin LOC =“AC24”; #CAM_SPI_SCLK - FMC2-G15(LA12_P) NET“fmc_imageon_vita_receiver_0_io_vita_spi_ *”IOSTANDARD =“LVCMOS25”; 所以,我不明白为什么LVDS_25没有被分配并且抱怨它需要VCCO = 1.8V。 |
> IO标准2:名称= DIFF_HSTL_II_18,VREF = NR,VCCO = 1.80,TERM = NONE,DIR = OUTPUT,DRIVE_STR = NR >我不明白为什么LVDS_25没有被分配并且抱怨它需要VCCO = 1.8V。 您的帖子提及LVDS_25,但ERROR消息是LVCMOS25和DIFF_HSTL_II_18之间的冲突,这两者都是输出,需要不同的VCCO电压。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com |
2424 浏览 7 评论
2826 浏览 4 评论
2294 浏览 9 评论
3375 浏览 0 评论
2465 浏览 15 评论
1237浏览 1评论
590浏览 1评论
452浏览 1评论
2006浏览 0评论
731浏览 0评论
GMT+8, 2024-12-25 15:36 , Processed in 2.996816 second(s), Total 78, Slave 62 queries .
