在数字电源的库中有这么一个函数PFC_InvRmsSqr,我看了介绍,但是对于PFC_InvRmsSqr_VminOverVmax:n和PFC_InvRmsSqr_Vmin:n的取值还是不是很明白,能不能请ti的高手在指导一下这两个变量怎么取值,谢谢!
Usage: This section explains how to use this module. The example assumes a PFC Stage designed for 264VAC to 85VAC and the voltage feedback is designed for peak 400V. Also, the minimum voltage used in this module is 80Vrms. Hence, PFC_InvRmsSqr_VminOverVmax:n: = _IQ30(80/283)=_IQ30(0.283)(怎么这两个都一样呢?283是怎么来的?) PFC_InvRmsSqr_Vmin:n: =<_IQ24(80/283)=_IQ24(0.283) 在后面的应用样例中 PFC_InvRmsSqr_VminOverVmax1=_IQ30(0.3913); PFC_InvRmsSqr_Vmin1=_IQ24(0.225);他们的值又不是相同的 |
2 个讨论
这两个值应该是一样的,它代表AC输入电压最小值和最大值的比值。超出这个范围的输入会被钳位。以为这里默认的工作电压范围是264VAC,所以输入信号的最大值要大于264.这里取了283.
PFC_InvRmsSqr_VminOverVmax:n: is the ratio of minimum over maximum voltage, which in this example is 80Vrms/283Vrms. This ratio is then represented in Q30 format. The PFC_InvRmsSqr_Vmin:n: is the same value represented in Q24 format. |
arikey 发表于 2020-6-17 15:46 FC_INVSQR_In1=&VacLineAvg; PFC_INVSQR_Out1=&InvAvgSqr; PFC_INVSQR_VminOverVmax1=_IQ30(0.2807); // 80V/285V PFC_INVSQR_Vmin1=_IQ24(0.17868); // 80V _IQ30(0.2807)可以理解,_IQ24(0.17868)是怎么通过80V算出来的? |
350 浏览 1 评论
544 浏览 2 评论
789 浏览 3 评论
660 浏览 1 评论
1140 浏览 1 评论
82浏览 29评论
290浏览 23评论
261浏览 20评论
210浏览 14评论
68浏览 13评论
GMT+8, 2024-12-27 23:51 , Processed in 0.746979 second(s), Total 43, Slave 37 queries .
