电子发烧友论坛|
ti工程师,你们好
我在使用串口时,把FIFO禁止,并且不使用DMA方式,只是单纯的中断方式,为何接收中断的触发还是以1/8 FIFIO来触发,也就是说每次一定要发送偶数个数据中断才触发,我看到DATASHEET上说明,如果禁止FIFO了,他会有个前置1字节的寄存器来保存接收到的数据,请问有什么办法来触发只要来数据了就出发接收中断呢? 以下是我初始化串口的代码片段: MAP_PRCMPeripheralClkEnable(PRCM_UARTA0, PRCM_RUN_MODE_CLK);MAP_PinTypeUART(PIN_55, PIN_MODE_3);MAP_PinTypeUART(PIN_57, PIN_MODE_3); MAP_UARTFIFODisable(UARTA0_BASE);MAP_UARTConfigSetExpClk(UARTA0_BASE, MAP_PRCMPeripheralClockGet(PRCM_UARTA0), UART0_BAUD_RATE, (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE | UART_CONFIG_PAR_NONE));MAP_UARTIntRegister(UARTA0_BASE, UARTIntHandler);MAP_UARTTxIntModeSet(UARTA0_BASE, UART_TXINT_MODE_EOT);MAP_UARTIntEnable(UARTA0_BASE, UART_INT_RX);MAP_UARTIntEnable(UARTA0_BASE, UART_INT_TX);MAP_UARTEnable(UARTA0_BASE);...这里是我检测和处理中断的代码片段: static void UARTIntHandler(void)[ long temp_data; unsigned long ulStatus = MAP_UARTIntStatus(UARTA0_BASE, true); if(UART_INT_RX & ulStatus)[//Receive Interrupt ulStatus ^= UART_INT_RX; MAP_UARTIntClear(UARTA0_BASE, UART_INT_RX); temp_data = HWREG(UARTA0_BASE + UART_O_DR); ... ] if(UART_INT_OE & ulStatus)[//Overrun Error Interrupt ulStatus ^= UART_INT_OE; MAP_UARTIntClear(UARTA0_BASE, UART_INT_OE); temp_data = HWREG(UARTA0_BASE + UART_O_DR); ] if(UART_INT_TX & ulStatus)[//Transmit Interrupt ulStatus ^= UART_INT_TX; MAP_UARTIntClear(UARTA0_BASE, UART_INT_TX); ... ] MAP_UARTIntClear(UARTA0_BASE, ulStatus);] |
9 个讨论
351 浏览 1 评论
546 浏览 2 评论
790 浏览 3 评论
660 浏览 1 评论
1140 浏览 1 评论
87浏览 29评论
325浏览 23评论
262浏览 20评论
211浏览 14评论
69浏览 13评论
GMT+8, 2024-12-29 05:09 , Processed in 0.836648 second(s), Total 70, Slave 59 queries .
