main.c [C] 纯文本查看 复制代码 /**/#include "main.h"#include "sys.h"#include "delay.h"#include "FreeRTOS.h"#include "task.h"#define START_TASK_PRIO 1 /*ÈÎÎñÓÅÏȼ¶*/#define START_STK_SIZE 128 /*ÈÎÎñ¶ÑÕ»´óС*/TaskHandle_t StartTask_Handle; /*ÈÎÎñ¾ä±ú*/void StartTask(void *pvParameters); /*ÈÎÎñº¯Êý*/#define TEST1_TASK_PRIO 2#define TEST1_STK_SIZE 50TaskHandle_t TEST1Task_Handle;void Test1Task(void *pvParameters);#define TEST2_TASK_PRIO 3#define TEST2_STK_SIZE 50TaskHandle_t TEST2Task_Handle;void Test2Task(void *pvParameters);uint8_t test1, test2, test3;/***** ÉùÃ÷ *****/static void SystemInitial(void);void StartTask(void *pvParameters){ taskENTER_CRITICAL(); /*½øÈëÁÙ½çÇø*/ xTaskCreate((TaskFunction_t )Test1Task, /*ÈÎÎñº¯Êý*/(const char * )"Test1Task", /*ÈÎÎñÃû³Æ*/(uint16_t )TEST1_STK_SIZE, /*ÈÎÎñ¶ÑÕ»´óС*/(void * )NULL, /*´«µÝ¸øÈÎÎñº¯ÊýµÄ²ÎÊý*/(UBaseType_t )TEST1_TASK_PRIO, /*ÈÎÎñÓÅÏȼ¶*/(TaskHandle_t )&TEST1Task_Handle); /*ÈÎÎñ¾ä±ú*/ xTaskCreate((TaskFunction_t )Test2Task,(const char * )"Test2Task",(uint16_t )TEST2_STK_SIZE,(void * )NULL,(UBaseType_t )TEST2_TASK_PRIO,(TaskHandle_t )&TEST2Task_Handle); vTaskDelete(StartTask_Handle); /*ɾ³ý¿ªÊ¼ÈÎÎñ*/ taskEXIT_CRITICAL(); /*ÍÆ³öÁÙ½çÇø*/} void Test1Task(void *pvParameters){ while (1) { test1 = ~test1; vTaskDelay(2);// DelayNms(2); }} void Test2Task(void *pvParameters){ while (1) { test2 = ~test2; vTaskDelay(5); }} static void SystemInitial(void){ DelayInitial();}int main(void){ SystemInitial(); /*´´½¨¿ªÊ¼ÈÎÎñ*/ xTaskCreate((TaskFunction_t )StartTask, /*ÈÎÎñº¯Êý*/(const char * )"StartTask", /*ÈÎÎñÃû³Æ*/(uint16_t )START_STK_SIZE, /*ÈÎÎñ¶ÑÕ»´óС*/(void * )NULL, /*´«µÝ¸øÈÎÎñº¯ÊýµÄ²ÎÊý*/(UBaseType_t )START_TASK_PRIO, /*ÈÎÎñÓÅÏȼ¶*/(TaskHandle_t )&StartTask_Handle); /*ÈÎÎñ¾ä±ú*/ /*¿ªÆôÈÎÎñµ÷¶È*/ vTaskStartScheduler();}/***************************END OF FILE***************************/ delay.c [C] 纯文本查看 复制代码 /**/#include "delay.h"#include "STM32f10x.h"#include "sys.h"#if SYSTEM_SUPPORT_OS #include "FreeRTOS.h" #include "task.h"#endifstatic uint8_t fac_us=0;//usÑÓʱ±¶³ËÊý static uint16_t fac_ms=0;//msÑÓʱ±¶³ËÊý,ÔÚucosÏÂ,´ú±íÿ¸ö½ÚÅĵÄmsÊý__IO uint32_t TimingDelay; extern void xPortSysTickHandler(void);extern void TimingDelayDecrement(void);//systickÖжϷþÎñº¯Êý,ʹÓÃFreeRTOSʱÓõ½void SysTick_Handler(void){ if(xTaskGetSchedulerState()!=taskSCHEDULER_NOT_STARTED)//ϵͳÒѾÔËÐÐ { xPortSysTickHandler(); } TimingDelayDecrement();} //³õʼ»¯ÑÓ³Ùº¯Êý//SYSTICKµÄʱÖӹ̶¨ÎªAHBʱÖÓ£¬»ù´¡Àý³ÌÀïÃæSYSTICKʱÖÓÆµÂÊΪAHB/8//ÕâÀïΪÁ˼æÈÝFreeRTOS£¬ËùÒÔ½«SYSTICKµÄʱÖÓÆµÂʸÄΪAHBµÄƵÂÊ£¡//SYSCLK:ϵͳʱÖÓÆµÂÊvoid DelayInitial(void){/* uint32_t reload;SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK); //Ñ¡ÔñÍⲿʱÖÓ HCLKfac_us=SystemCoreClock/1000000; //²»ÂÛÊÇ·ñʹÓÃOS,fac_us¶¼ÐèҪʹÓÃreload=SystemCoreClock/1000000; //ÿÃëÖӵļÆÊý´ÎÊý µ¥Î»ÎªM reload*=1000000/configTICK_RATE_HZ; //¸ù¾ÝconfigTICK_RATE_HZÉ趨Òç³öʱ¼ä //reloadΪ24λ¼Ä´æÆ÷,×î´óÖµ:16777216,ÔÚ72MÏÂ,Ô¼ºÏ0.233s×óÓÒfac_ms=1000/configTICK_RATE_HZ; //´ú±íOS¿ÉÒÔÑÓʱµÄ×îÉÙµ¥Î» SysTick->CTRL|=SysTick_CTRL_TICKINT_Msk; //¿ªÆôSYSTICKÖжÏSysTick->LOAD=reload; //ÿ1/configTICK_RATE_HZÃëÖжÏÒ»´ÎSysTick->CTRL|=SysTick_CTRL_ENABLE_Msk; //¿ªÆôSYSTICK */ fac_us=SystemCoreClock/1000000; //²»ÂÛÊÇ·ñʹÓÃOS,fac_us¶¼ÐèҪʹÓà fac_ms=1000/configTICK_RATE_HZ; //´ú±íOS¿ÉÒÔÑÓʱµÄ×îÉÙµ¥Î» /* * SystemCoreClock / 1000 1msÖжÏÒ»´Î * SystemCoreClock / 100000 10usÖжÏÒ»´Î * SystemCoreClock / 1000000 1usÖжÏÒ»´Î */ if (SysTick_Config(SystemCoreClock / 1000)) { while (1); } /*¹Ø±Õsystick timer¶¨Ê±Æ÷*/ /*SysTick->CTRL &= ~SysTick_CTRL_ENABLE_Msk;*/ /*ʹÄܵδð¶¨Ê±Æ÷*/ SysTick->CTRL |= SysTick_CTRL_ENABLE_Msk; } //ÑÓʱnus//nus:ÒªÑÓʱµÄusÊý.//nus:0~204522252(×î´óÖµ¼´2^32/fac_us@fac_us=168) void DelayNus(uint32_t nus){uint32_t ticks;uint32_t told,tnow,tcnt=0;uint32_t reload=SysTick->LOAD;//LOADµÄÖµ ticks=nus*fac_us; //ÐèÒªµÄ½ÚÅÄÊý told=SysTick->VAL; //¸Õ½øÈëʱµÄ¼ÆÊýÆ÷Öµwhile(1){tnow=SysTick->VAL;if(tnow!=told){ if(tnow [C] 纯文本查看 复制代码 /* FreeRTOS V9.0.0 - Copyright (C) 2016 Real Time Engineers Ltd. All rights reserved VISIT http://www.FreeRTOS.org TO ENSURE YOU ARE USING THE LATEST VERSION. This file is part of the FreeRTOS distribution. FreeRTOS is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License (version 2) as published by the Free Software Foundation >>>> AND MODIFIED BY <<<< the FreeRTOS exception. *************************************************************************** >>! NOTE: The modification to the GPL is included to allow you to !<< >>! distribute a combined work that includes FreeRTOS without being !<< >>! obliged to provide the source code for proprietary components !<< >>! outside of the FreeRTOS kernel. !<< *************************************************************************** FreeRTOS is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Full license text is available on the following link: http://www.freertos.org/a00114.html *************************************************************************** * * * FreeRTOS provides completely free yet professionally developed, * * robust, strictly quality controlled, supported, and cross * * platform software that is more than just the market leader, it * * is the industry's de facto standard. * * * * Help yourself get started quickly while simultaneously helping * * to support the FreeRTOS project by purchasing a FreeRTOS * * tutorial book, reference manual, or both: * * http://www.FreeRTOS.org/Documentation * * * *************************************************************************** http://www.FreeRTOS.org/FAQHelp.html - Having a problem? Start by reading the FAQ page "My application does not run, what could be wrong?". Have you defined configASSERT()? http://www.FreeRTOS.org/support - In return for receiving this top quality embedded software for free we request you assist our global community by participating in the support forum. http://www.FreeRTOS.org/training - Investing in training allows your team to be as productive as possible as early as possible. Now you can receive FreeRTOS training directly from Richard Barry, CEO of Real Time Engineers Ltd, and the world's leading authority on the world's leading RTOS. http://www.FreeRTOS.org/plus - A selection of FreeRTOS ecosystem products, including FreeRTOS+Trace - an indispensable productivity tool, a DOS compatible FAT file system, and our tiny thread aware UDP/IP stack. http://www.FreeRTOS.org/labs - Where new FreeRTOS products go to incubate. Come and try FreeRTOS+TCP, our new open source TCP/IP stack for FreeRTOS. http://www.OpenRTOS.com - Real Time Engineers ltd. license FreeRTOS to High Integrity Systems ltd. to sell under the OpenRTOS brand. Low cost OpenRTOS licenses offer ticketed support, indemnification and commercial middleware. http://www.SafeRTOS.com - High Integrity Systems also provide a safety engineered and independently SIL3 certified version for use in safety and mission critical applications that require provable dependability. 1 tab == 4 spaces!*/#ifndef FREERTOS_CONFIG_H#define FREERTOS_CONFIG_H#include "sys.h"//#include "usart.h"//Õë¶Ô²»Í¬µÄ±àÒëÆ÷µ÷Óò»Í¬µÄstdint.hÎļþ#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__) #include |
4个回答
麻烦直接用示波器测试!!!不要看MDK的这啥软件仿真
800 浏览 0 评论
1156 浏览 1 评论
2531 浏览 5 评论
2863 浏览 9 评论
2714 浏览 6 评论
1092浏览 3评论
197浏览 2评论
463浏览 2评论
376浏览 2评论
458浏览 1评论
GMT+8, 2024-12-25 04:42 , Processed in 0.879463 second(s), Total 52, Slave 44 queries .
