专家您好:
我用的是28034,需要AD以下功能: 1.同时采样模式,且同时采样4个AD通道 2.触发源都是PWM2_SOCA 3.等4个AD转换完成后触发ADCINT1中断,只此一个中断即可 以下是我的配置代码,请帮忙审核,谢谢 EALOW; AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 1; //SOC0/SOC1同时采样 //SOC0 AdcRegs.ADCSOC0CTL.bit.ACQPS=6;//SOC0采样窗口 AdcRegs.ADCSOC0CTL.bit.CHSEL = 0; //soc通道选择A0 ---ADCRESULT0 AdcRegs.ADCSOC0CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA //SOC1 AdcRegs.ADCSOC1CTL.bit.ACQPS=6;//SOC1采样窗口 AdcRegs.ADCSOC1CTL.bit.CHSEL = 8; //soc通道选择B0 ---ADCRESULT1 AdcRegs.ADCSOC1CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA AdcRegs.ADCSAMPLEMODE.bit.SIMULEN2 = 1; //SOC2/SOC3同时采样 //SOC2 AdcRegs.ADCSOC0CTL.bit.ACQPS=6;//SOC2采样窗口 AdcRegs.ADCSOC0CTL.bit.CHSEL = 1; //soc通道选择A1 ---ADCRESULT2 AdcRegs.ADCSOC0CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA //SOC3 AdcRegs.ADCSOC1CTL.bit.ACQPS=6;//SOC3采样窗口 AdcRegs.ADCSOC1CTL.bit.CHSEL = 9; //soc通道选择B1 ---ADCRESULT3 AdcRegs.ADCSOC1CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //结果存入寄存器才产生中断 PieVectTable.ADCINT1 = &ADC_convered; !!!AdcRegs.INTSEL1N2.bit.INT1SEL = 1; //中断线1选择soc1 !!!AdcRegs.INTSEL1N2.bit.INT1CONT = 0; AdcRegs.INTSEL1N2.bit.INT1E = 1; //中断使能 PieCtrlRegs.PIEIER1.bit.INTx1 = 1; //使能int1.1 EDIS; 加!!!标注的句子是网上的例程,有点看不明白。唉 |
4 个讨论
Seven,
你的配置有问题。 EALOW; AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 1; // 这个配置表示SOC0,SOC1同时采样 AdcRegs.ADCSAMPLEMODE.bit.SIMULEN1 = 1; //这个配置表示SOC2,SOC3同时采样。 //SOC0 这里要SOC0 SOC1同时 采样 A0,B0 AdcRegs.ADCSOC0CTL.bit.ACQPS=6;//SOC0采样窗口 AdcRegs.ADCSOC0CTL.bit.CHSEL = 0; //soc通道选择A0 ---ADCRESULT0 AdcRegs.ADCSOC0CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA //SOC2 这里要SOC2同时采样 A1,B1 AdcRegs.ADCSOC2CTL.bit.ACQPS=6;//SOC1采样窗口 AdcRegs.ADCSOC2CTL.bit.CHSEL = 1; //soc通道选择B0 ---ADCRESULT1 AdcRegs.ADCSOC2CTL.bit.TRIGSEL=7;//触发源-PWM2-SOCA Eric - ERIC |
那底下的这些呢?能否完成转换完成后触发ADCINT1中断的功能?谢谢: AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //结果存入寄存器才产生中断 PieVectTable.ADCINT1 = &ADC_convered; !!!AdcRegs.INTSEL1N2.bit.INT1SEL = 1; //中断线1选择soc1 !!!AdcRegs.INTSEL1N2.bit.INT1CONT = 0; AdcRegs.INTSEL1N2.bit.INT1E = 1; //中断使能 PieCtrlRegs.PIEIER1.bit.INTx1 = 1; //使能int1.1 EDIS; 加!!!标注的句子是网上的例程,有点看不明白。唉 |
广州洋钒 发表于 2020-6-8 16:09 AdcRegs.INTSEL1N2.bit.INT1SEL = 1; AdcRegs.INTSEL1N2.bit.INT1CONT = 0; 这两句的功能是设置 ADCINT1 这一中断的中断源为 EOC1,即在 SOC1 所触发的 ADC 操作结束之后触发 ADCINT1 的中断响应函数;并将中断标志位设置为单次触发等待清除。 具体请参考威廉希尔官方网站 文档中关于 INTSELxNy 寄存器的说明:http://www.ti.com.cn/cn/lit/ug/spruge5f/spruge5f.pdf |
272 浏览 1 评论
1012 浏览 0 评论
612 浏览 1 评论
458 浏览 1 评论
650 浏览 2 评论
244浏览 29评论
1211浏览 23评论
349浏览 20评论
324浏览 14评论
180浏览 13评论
GMT+8, 2025-2-24 14:27 , Processed in 0.891545 second(s), Total 46, Slave 41 queries .
