供应HITROL进口浮子液位计HR-30S-4F
吴经理:132.4667.5433 /0755-26998458 工作Q:1139878854 韩国HITROL HT-100RV,HR-30V-2F,HR-30V-4F,HLC-200,HLC-300,HTA-2004,HLC-901L,HFS-2T,HM-12S,HT-100RSH HTM-930,HLC-901P,HT-100R,HT-100CT-2,HQ-66S-3F,HT-100RTH,HR-30TH-2F-EX,HLV-300,HLV-310, HT-100CTH-2,HT-100CTWH-2,HTM-20M-A,HTM-20N,HT-100PT,HT-100RS-EX,HR-30S-2F,HR-30SH-2F, HQ-66-3F,HCC-96RF-SH,HCC-96RF-S,HR-30C-4F,HM-90-2F,HM-30-1F,HCC-95RF-C,HR-30S-3F,HTM-901, RT14-20,HR-30S-1F-EX,HR-30S-3F-EX,HTM-20N-A,HQ-66-4F,HCC-75P,HR-30S-5F,HCC-609N-FS, HR-10S-1F,HR-30S-1F,HR-30S-2F-EX,HR-30T-2F,HM-90-1F-EX,HT-100RT,HT-100RT-EX,HQ-36-1F, HQ-36-2F,HQ-36-3F,HR-30TS-3F-EX,HSC-10TT-1F,HR-30TH-2F,HCC-75R-FS,HTM-929,HR-30S-4F, HR-30CH-EX,HR-30H,HR-30H-Ex,HR-30S,HR-30S-EX,HR-30SH,HR-30SH-EX,HR-30T,HR-30T-EX,HR-30TH, HR-30TH-EX,HR-30V,HR-30V-EX,HM-12D,HM-12H,HM-12H-EX,HM-12H-L,HM-12H-L-EX,HM-12H-SP, HM-12H-SP-EX,HM-12S,HM-12W,HQ-3,HQ-6,HQ-66P,HQ-66S,HQM-7,HQM-77P,HR-10S,HR-10T,HR-10L-Ex, HM-90-EX,HM-90H,HM-90H-EX,HLC-200C-L,HT-200CT-2,HCC-95PH,HCC-95PW,HCC-95PWH,HPC-95PH, HPC-95PW,HPC-95PWH,HCC-75RD,HCC-75RDH,HCC-75RH,HCC-75RW,HCC-75RWH,HLC-75R-L,HLC-75R-P, HPC-95RH,HPC-95RW,HPC-95RWH,HCC-609N-RD,HCC-609NH,HCC-609NW,HCC-609NWH,HPC-609NH, HPC-609NW,HPC-609NWH,HT-100CTW-2,HPC-100CTH-2,HPC-100CTW-2,HPC-100CTWH-2,HT-100CH-2, HT-100CW-2,HT-100CWH-2,HLC-100C-P,HPC-100CTH,HPC-100CTW, HPC-100CTWH,HT-100CTH,HT-100CTW,HT-100CTWH,HCC-95RF-CH,HCC-96RF-RH,HLC-96RF-R, HLC-96RF-RACK,HPC-96RF-RH,HPV-20N-A,HPV-20N-B,HPV-20NH-A,HPV-20NH-B, HTM-20N-B,HTM-20N-C,HTM-20NH-A,HTM-20NH-B,HLC-901-L,HLC-901-P,HLC-900-L,HLC-900-P, HTM-920H,HTM-921H,HLC-970-L,HE-2D,HE-2H,HE-2V,HE-3H,HE-3H-S,HE-3H-SP,HE-3S,HE-3V,HE-4H, HE4H-S,HE-4H-SP,HE-4S,HE-4V,HE-5H,HE-5H-S,HE-5H-SP,HE-5S,HE-5V,HE-6V,HE-7V,HLV-300-EX, HLV-300H,HLV-310AP,HLV-310H,HLV-310HP,HLV-320L,HM-100A,HM-100S,HM-100V,HLT-1112, HMF-800R,HMF-800S,HOP-C,HKOP-F,HKOP-N,HHG-1FA,HHG-1FB,HHG-2FA,HHG-2FB, HT-100R R/I,HTA-2002,HTA-2003,HTA-2004-1111,HTA-4003,HTA-4004,HI-100A,HI-100S,HT-100FI HUL-2000T,HUL-2000S,HUT-2000T,HUT-2000S,HT-100F,HM-95,HM-90S,HR-30,HM-12,HM-10, HQ-66,HQ-36,CS-1000-Ex,HQM-77,HR-10,HR-50,HR-10L,HM-30,HM-90,HT-200C,HCC-95P,HPC-95P, HCC-75R,HPC-95R,HCC-609N,HPC-609N,HPC-100CT-2,HT-100C-2,HT-100CT,HPC-100CT, HCC-96RF-R,HPC-96RF-R,HPV-20N,HTM-920,HTM-921,HNV-970,HTM-230, HTM-330,HTM-430,HP-1A,HE-1S,HFW-100W,HTG-200,HTG-100,HT-100W,HLG-100F,HTML-TC, HTML-TM,HTML-S,HFR-981,HFT-7000,HMF-800,HUT-3000,HUT-2001S,HUL-2200S, HUL-2300S,HUL-2100N,HUL-2100S,HUL-2100T,HT-100PS,HCC-96RF,HQQ-66, HQQ-77,HLT-1110,HLT-2110,HTG-100S,HTG-200D,HUL-2100,HTM-920 HUL-2300,HUL-2200,HT-100R-EX,HT-100RH,HT-100RH-EX,HT-100RS,HT-100RS-L, HT-100RSH,HT-100RSH-EX,HT-100RSH-L,HT-100RT-L,HT-100RTH-EX, HT-100RV-EX,HT-100RV-L,HT-100FI,HM-95-EX,HM-95H,HM-95H-EX,HM-95V,HM-95V-EX, HM-95VH,HM-95VH-EX,HM-90S-EX,HM-90SH,HM-90SH-EX,HR-30-Ex,HR-30C,HR-30C-EX,HR-30CH, HCC-75P系列是电容式液/料位开关,物料的物位高低变化导致探头被覆盖区域大小发生变 化, 从而导致电容值发生变化。 特性: 广泛用于固体、粉末、液体等各种介质 适用于介电常数低的介质 高灵敏度和高稳定性 使用寿命长 易于安装和标定 可在现场进行操作检查 适用于带搅拌器的容器 可根据现场安装条件选用不同的传感器类型 工作原理: 物料的物位高低变化导致探头被覆盖区域大小发生变化,从而导致电容值发生变化。探头与罐壁(导 电材料制成)构成一个电容。探头处于空气中时,测量到的是一个小数值的初始电容值。当罐体中有 料注入时,电容值将随探头被物料所覆盖区域面积的增加而相应地增大。 应用: 液体 各种燃料、溶剂、酸、碱,液化气、纯 水等。 混合液体 工业废水、城市污水、农药、各种污泥 和水溶液等。 接触面 油和水、水中的汞、酒精和酸、液体中 的沉淀物、液体和泡沫等。 成团的 煤、石灰石、铁矿石和集料等。 粘性材质 粘土、油泥、清漆、油漆、油脂、粘合 剂、石蜡、干酪和蜂蜜等。 粉 塑料粉、石粉、碳、氯化铁粉、淤泥、 糖和面粉等。 颗粒 塑料颗粒、金属颗粒、化工化肥、医药 、粮食、食品等。 安装建议: HCC-75P一般安装在容器的顶部和侧部,进行物位报警。因为在液位开关中安装 了接地电极所以适用于金属或合成树脂的容器,检测结果并不受容器材料的影响。 1. 顶部安装 在探头上的介质的积累对这种安装方式的检测没有太大的影响,但因为它只测量探头末端的电平,所 以其灵敏度低于侧安装,并且它不适合检测低介电常数的介质物位。 2. 侧部安装 高灵敏度测量可采用侧安装方式,因为它是整个探头去测量,但要避免传感探头上介质积聚引起的故障 |
GMT+8, 2025-1-24 00:54 , Processed in 0.327396 second(s), Total 34, Slave 26 queries .
