数字矩阵芯片方案
VSC3104 Up to 6.5 Gbps 4x4 Asynchronous VSC3303 Up to 8.5 Gbps 4x4 Asynchronous with support of SAS/SATA VSC3304 Up to 8.5 Gbps 4x4 Asynchronous VSC3108 Up to 6.5 Gbps 8x8 Asynchronous VSC3008 Up to 11 Gbps 8x8 Asynchronous VSC3308 Up to 11.5 Gbps 8x8 Asynchronous with advanced EQ VSC3208 150 Mbps to 4.25 Gbps 8x8 Synchronous using CDR VSC3312 Up to 6.5 Gbps 12x12 Asynchronous with support for SAS/SATA VSC3212 150 Mbps to 4.25 Gbps 12x12 Synchronous using CDR VSC3316 Up to 11.5 Gbps 16x16 Asynchronous VSC3340 Up to 6.5 Gbps 40x40 Asynchronous with power-scaling green modes VSC3139 Up to 4.25 Gbps 72x72 Asynchronous VSC3172 Up to 6.5 Gbps 72x72 Asynchronous VSC3140 Up to 4.25 Gbps 144x144 Asynchronous VSC3144 Up to 10.709 Gbps 144x144 Asynchronous
最佳答案
1 条评论
可以选择视频矩阵柜,不知道需要几路的控制。
1 条评论
Vitesse 的一些数字矩阵芯片方案
2010-04-28 12:07:12 分享到: Vitesse was first to introduce input signal equalization in crosspoint switches and now has a decade of successful product developments with more than a dozen products in production. Key Features • Highest data rates in the industry (up to 11 Gbps) • Programmable individual and global input signal equalization and output drive levels • Programmable power-down for unused channels • Differential current-mode logic data output driver • On-chip input and output terminations • Per-channel clock and data recovery (VSC3208 and VSC3212) • Support for signal monitoring and OOB signal forwarding for SAS/SATA applications (VSC3208, VSC3304, and VSC3312) Product Data Rate per Serial Lane Channels Distinction VSC3104 Up to 6.5 Gbps 4x4 Asynchronous VSC3303 Up to 8.5 Gbps 4x4 Asynchronous with support of SAS/SATA VSC3304 Up to 8.5 Gbps 4x4 Asynchronous VSC3108 Up to 6.5 Gbps 8x8 Asynchronous VSC3008 Up to 11 Gbps 8x8 Asynchronous VSC3308 Up to 11.5 Gbps 8x8 Asynchronous with advanced EQ VSC3208 150 Mbps to 4.25 Gbps 8x8 Synchronous using CDR VSC3312 Up to 6.5 Gbps 12x12 Asynchronous with support for SAS/SATA VSC3212 150 Mbps to 4.25 Gbps 12x12 Synchronous using CDR VSC3316 Up to 11.5 Gbps 16x16 Asynchronous VSC3340 Up to 6.5 Gbps 40x40 Asynchronous with power-scaling green modes VSC3139 Up to 4.25 Gbps 72x72 Asynchronous VSC3172 Up to 6.5 Gbps 72x72 Asynchronous VSC3140 Up to 4.25 Gbps 144x144 Asynchronous VSC3144 Up to 10.709 Gbps 144x144 Asynchronous |
20948 浏览 1 评论
【KV260威廉希尔官方网站 分享】宿主机构建Gstreamer
1075 浏览 0 评论
硬创大赛项目专访 | 田奕鑫:专注细分领域创新,我们和行业巨头“化敌为友”
87866 浏览 1 评论
硬创大赛项目专访 | 王猛:专研降噪威廉希尔官方网站 ,让中国的黑科技产品服务全球用户
24164 浏览 1 评论
9216 浏览 3 评论
GMT+8, 2024-9-22 01:02 , Processed in 0.687429 second(s), Total 87, Slave 69 queries .
