数码管和矩阵键盘实现简易计算器,这段代码在实现的时候只能显示第一次按下的数字就无法操作了,不知道是哪里错了,求助
#include #include #define uchar unsigned char #define uint unsigned int ***it duan=P2^6; ***it wei=P2^7; uchar temp; uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; uchar code weima[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf}; void display(unsigned long a); uchar keyscan(); void delay(uint xms); void main() { unsigned long num1=0,num2=0,dispbuf=0; unsigned char key,flag=1,fuhao; while(1) { if(flag==1) { key=keyscan(); if(key<10) { num1=num1*10+key; dispbuf=num1; } else if(key==12) { fuhao='+'; flag=2; } else if(key==13) { fuhao='-'; flag=2; } else if(key==14) { fuhao='*'; flag=2; } else if(key==15) { fuhao='/'; flag=2; } } else if(flag==2) { key=keyscan(); if(key<10) { num2=num2*10+key; dispbuf=num2; } else if(key==11) { switch(fuhao) { case'+':dispbuf=num1+num2;break; case'-':dispbuf=num1-num2;break; case'*':dispbuf=num1*num2;break; case'/':dispbuf=num1/num2;break; } } } display(dispbuf); } } void maco(unsigned char du,unsigned char we) { duan=1; P0=table[du]; duan=0; P0=0xff; wei=1; P0=weima[we]; wei=0; } void display(unsigned long x) { int i; unsigned char a[6]; if(x==0) { maco(0,1); } else { for(i=0;x!=0;i++) { a=x%10; x/=10; } switch(i) { case 1: maco(a[0],1); while(1); case 2: while(1) { maco(a[1],1); delay(1); maco(a[0],2); delay(1); } case 3: while(1) { maco(a[2],1); delay(1); maco(a[1],2); delay(1); maco(a[0],3); delay(1); } case 4: while(1) { maco(a[3],1); delay(1); maco(a[2],2); delay(1); maco(a[1],3); delay(1); maco(a[0],4); delay(1); } case 5: while(1) { maco(a[4],1); delay(1); maco(a[3],2); delay(1); maco(a[2],3); delay(1); maco(a[1],4); delay(1); maco(a[0],5); delay(1); } case 6: while(1) { maco(a[5],1); delay(1); maco(a[4],2); delay(1); maco(a[3],3); delay(1); maco(a[2],4); delay(1); maco(a[1],5); delay(1); maco(a[0],6); delay(1); } } } } |
你的代码好乱,你看看是不是你的keyscan放的位置不对。
872 浏览 0 评论
1191 浏览 1 评论
2566 浏览 5 评论
2904 浏览 9 评论
2762 浏览 6 评论
1213浏览 3评论
216浏览 2评论
490浏览 2评论
400浏览 2评论
482浏览 1评论
GMT+8, 2025-1-26 15:17 , Processed in 0.799888 second(s), Total 46, Slave 38 queries .
