苏州顺芯ES8374针对需要单路ADC和单路DAC且需要功放的产品,内置功放可取代外置3W或以下的功放。深圳锦宏世纪科技李工 *** 故事机和行车记录仪产品的选择!
High performance and low power multi-bit delta-sigma audio ADC and DAC ? I2S/PCM master or slave serial data port ? Two pairs of analog input with differential input option ? Mono analog output ? 256/384Fs, USB 12/24 MHz, fractional PLL for wide range of system clocks ? Standard audio clock output ? Sophisticated analog input and output routing, mixing and gain ? GPIO ? I2C interface ADC ? 24-bit, 8 to 96 kHz sampling frequency ? 95 dB signal to noise ratio, -85 dB THD+N ? Low noise pre-amplifier ? Noise reduction filters ? Auto level control (ALC) and noise gate ? Support analog and digital microphone ? Microphone bias DAC ? 24-bit, 8 to 96 kHz sampling frequency ? 95 dB signal to noise ratio, -85 dB THD+N ? 1.25W@8Ω/5V or 1.8W@4Ω/4.2V mono class D speaker driver ? Dynamic range compression ? Headphone and external mic detection ? Pop and click noise suppression Low Power ? 3.3V to 5V operation ? 32 mW playback; 42 mW playback and record ? Low standby current
很棒棒哦,加油,值得学习
RK3588 HDMI in 接入设备如何获取HDMI in 传入的音频?
1383 浏览 1 评论
23381 浏览 1 评论
【KV260威廉希尔官方网站 分享】宿主机构建Gstreamer
1252 浏览 0 评论
硬创大赛项目专访 | 田奕鑫:专注细分领域创新,我们和行业巨头“化敌为友”
94620 浏览 1 评论
硬创大赛项目专访 | 王猛:专研降噪威廉希尔官方网站 ,让中国的黑科技产品服务全球用户
24462 浏览 1 评论
GMT+8, 2024-12-24 08:19 , Processed in 0.369320 second(s), Total 38, Slave 29 queries .
