NCS8803 HDMI-to-eDP w/ Scaler guo18770755707/Q1456415694
Features --Embedded-DisplayPort (eDP) Output 1/2/4-lane eDP @ 1.62/2.7Gbps per lane HD to WQXGA (2560*1600) supported Up to 6dB pre-emphasis --HDMI Input HDMI 1.4a supported RGB444/YCbCr444/YCbCr422 supported Pixel clock up to 340MHz 2-channel audio supported Adaptive equalization --Reference Clock Any freq. between 19MHz and 100MHz Crystal or single-ended clock input Built-in 5000ppm SSC generator --Misc I2C for chip configuration Built-in eDP handshake protocol I2C-AUX channel for TCON/DPCD/EDID control Built-in video test pattern --Power 1.2V core supply 2.5V or 3.3V IO supply Power consumption ~ 150mW @ 2560*1600*24bit*60Hz Deep-sleep mode power <1mW --Package QFN-56 (7mm x 7mm) package RoHS Compliant --Availability Samples by the end of 2016 Block Diagram |
GMT+8, 2025-2-24 09:16 , Processed in 0.588774 second(s), Total 58, Slave 43 queries .
