韩国HITROL HQ-36-2F 液位计开关 韩国HITROL HQ-36-2F 液位计开关
详细请致电:132.4667.5433/0755-26998458 工作Q:1139878854 经过四十年的发展,HITROL已经成长为一家致力于测量仪表领域的专业化公司。我们十分重视持续地投入开发研究工作,在专业领域的长期积累为我们的产品提供了严格的质量保证,使得我们可以向客户供应高精度和具有可靠性品质的产品。此外,HITROL也一直重视出口市场,力促HITROL产品走向全球化。 HITROL下属分公司FCC(流体校验中心)具有符合国际标准(ISO17025)的大型流量标准体系,负责HITROL所以产品的校正和测试。如今FCC已经成为具有国际水准的校正及测试实验室,助力HITROL向国内外客户提供符合国际标准的高精度仪表。 HITROL主营产品:浮子式液位变送器,液位开关,浮球液位计,海特勒射频式料位开关桨式料位开关、振动料位开关. 韩国HITROL液位浮球开关是一种结构简单,使用方面,安全可靠的液位控制器件,其作用类似于保险丝的作用,保护设备的安全。其广泛应用于造船、造纸、印刷、发电机设备、石油化工、食品工业、水处理、电工、染料工业、油压机械等。 浮球开关相比优势: 比一般机械速度快,工作寿命长,与电子开关相比,它又有抗负载冲击能力强的特点。一只产品可以实现多点控制器。 浮球开关威廉希尔官方网站 优势: 浮球开关不含导致故障发生和波纹管,弹簧,密封的部件,而是采用真浮子驱动开关内部磁铁,浮球开关的简捷的杠杆使开关瞬间动作,浮子悬臂角限位设计,防止浮子垂直。 品牌:韩国HITROL 型号:HT-100RV-EX 类别:浮子式液位变送器 推荐型号: HT-100R HT-100R-EX HT-100RH HT-100RH-EX HT-100RS HT-100RS-EX HT-100RSH HT-100RSH-EX HT-100RT HT-100RT-EX HT-100RTH HT-100RTH-EX HT-100RV HT-100RV-EX HT-100R Series is a Float Type Level Transmitter which continuously measures the liquid level in the tank by usage of buoyancy.This transmitter can be easily installed and adjusted, and can be especially applied for corrosive and acidic liquids with various anti-corrosive materials such as PVC or Teflon for the sensor. HT-100R Series is extensively used to measure liquid levels in various industries. HT-100R系列浮子式液位变送器,利用浮力连续测量罐内液位。该变送器安装、调试方便,特别适用于腐蚀性、酸性液体,传感器采用PVC、聚四氟乙烯等多种防腐材料。HT-100R系列广泛用于各行业的液位测量。 原理: As liquid level is changed in the tank, the float which is manufactured in accordance with the specific gravity of liquid moves upward or downward along the guide pipe with the same liquid level by buoyancy. The magnet is installed in the float and it activates reed switches that are installed in the guide pipe continuously, and activation of reed switches changes the resistance value. The variation of resistance value is transmitted to the R/I converter in the housing and it converts this resistance value to current output of DC 4~20mA continuously. 当罐内液位发生变化时,根据液体比重制造的浮子通过浮力沿同一液位的导向管上下移动。磁铁安装在浮子上,它连续地激活安装在导气管中的簧片开关,簧片开关的激活改变了阻值。电阻值的变化被传输到机壳内的R/I转换器,并将该电阻值连续转换为直流4~20mA的电流输出。 产品特点: ● Widely used to measure various liquid levels with high resolution (Resolution 10mm) ● Applicable to corrosive and acidic liquids with anti-corrosive material for the sensor (PVC and Teflon) ● Applicable to explosion area (Ex-Proof version) ● Strong structure and high reliability ●广泛用于高分辨率测量各种液位(分辨率10mm) ●适用于含传感器防腐材料的腐蚀性、酸性液体(PVC、聚四氟乙烯) ●适用于爆炸区域(防爆型) ●结构坚固,可靠性高 应用: ● Water and Wastewater facilities ● Oil, Acid , Solvent, LPG, Petrochemicals ● Drinks, Beer equipment, etc. ● Other Industries ●水和废水处理设施 ●石油、酸、溶剂、液化石油气、石化产品 ●饮料、啤酒设备等 ●其他行业 威廉希尔官方网站 规格: ● Mounting method : Flange ● Process connection : 2 inch(50A) to 4 inch(100A) ● Temperature : Std. 80℃ (S.S / TEFLON) Max. 150℃ (S.S / TEFLON) Max . 60℃ (PVC) ● Pressure : Max. 20 kg/cm2 (S.S) Max. 0.5 kg/cm2 (TEFLON / PVC) ● Enclosure : Weather-Proof(IP 65) Ex-Proof(Ex d IIC T4,IP65) ● Cable Entry : PF 3/4"(F) ● Material : Housing --- P.C(Std.), AL.C Process connection --- SUS 304,316L SUS 316L + TEFLON PVC Guide pipe --- SUS 316L, TEFLON, PVC Float --- SUS 316L, TEFLON, PVC ● Accuracy : ±10mm of F.S 安装方法:法兰 ●工艺连接:2英寸(50A)至4英寸(100A) ●温度:Std. 80℃(S。S /聚四氟乙烯) Max. 150℃ (S.S / TEFLON) Max . 60℃ (PVC) ●压力:Max . 20 kg / cm2 (S . S) 最大0.5 kg/cm2(特氟隆/ PVC) ●Enclosure: IP Weather-Proof (65) Ex- proof (Ex d IIC T4,IP65) ●电缆入口:PF 3/4"(F) ●材料:外壳--- P.C(Std.), AL.C 流程连接——SUS 304,316L SUS 316L + TEFLON PVC 导向管——SUS 316L, TEFLON, PVC Float - SUS 316L, TEFLON, PVC ●Accuracy:±10mm of F . S 威廉希尔官方网站 数据: ● Ambient Temp. : -20℃ ~ +60℃ ● Power source: DC 24V ● Output signal : DC 4~20mA(2-wire) ●环境温度:-20℃~ +60℃ ●电源:DC 24V ●输出信号:DC 4~20mA(2线) |
GMT+8, 2025-2-24 17:28 , Processed in 0.520600 second(s), Total 66, Slave 47 queries .
