我在STM32F767上移植RAW LWIP传输图片时,发现死机的现象,后在仿真调试时,发现是进入监听块的时候发生的硬件错误struct tcp_PCB *
tcp_listen_with_backlog(struct tcp_pcb *pcb, u8_t backlog) { struct tcp_pcb_listen *lpcb; LWIP_UNUSED_ARG(backlog); LWIP_ERROR("tcp_listen: pcb already connected", pcb->state == CLOSED, return NULL); /* already listening? */ if (pcb->state == LISTEN) { return pcb; } #if SO_REUSE if (ip_get_option(pcb, SOF_REUSEADDR)) { /* Since SOF_REUSEADDR allows reusing a local address before the pcb's usage is declared (listen-/connection-pcb), we have to make sure now that this port is only used once for every local IP. */ for(lpcb = tcp_listen_pcbs.listen_pcbs; lpcb != NULL; lpcb = lpcb->next) { if (lpcb->local_port == pcb->local_port) { if (ip_addr_cmp(&lpcb->local_ip, &pcb->local_ip)) { /* this address/port is already used */ return NULL; } } } } #endif /* SO_REUSE */ lpcb = (struct tcp_pcb_listen *)memp_malloc(MEMP_TCP_PCB_LISTEN);在此处分配内存池时,无法分配,进入死循环 ... 在这之前我定义了三个数组,怀疑是不是跟这数组有关,但不知道问题出在哪? u32 *dcmi_line_buf[2]; |
三个数组,及大小
u32 *dcmi_line_buf[2]; //RGB屏时,摄像头采用一行一行读取,定义行缓存 u32 *jpeg_data_buf; #define jpeg_buf_size 8*1024*1024 //定义JPEG数据缓存jpeg_buf的大小(8M字节) #define jpeg_line_size 2*1024 //定义DMA接收数据时,一行数据的最大值 dcmi_line_buf[0]=mymalloc(SRAMIN,jpeg_line_size*4); //为jpeg dma接收申请内存 dcmi_line_buf[1]=mymalloc(SRAMIN,jpeg_line_size*4); //为jpeg dma接收申请内存 jpeg_data_buf=mymalloc(SRAMEX,jpeg_buf_size); |
2475 浏览 7 评论
2252 浏览 5 评论
3040 浏览 3 评论
2714 浏览 8 评论
2681 浏览 4 评论
470浏览 1评论
736浏览 0评论
822浏览 0评论
512浏览 0评论
321浏览 0评论
GMT+8, 2024-9-20 21:26 , Processed in 0.865182 second(s), Total 45, Slave 40 queries .
