5 个讨论
小Qhhui 发表于 2020-3-19 10:06 明白了,中断后按键回调函数OnBoard_KeyCallback会查询按键状态,同时关闭中断直到按键释放。 /* If any key is currently pressed down and interrupt is still enabled, disable interrupt and switch to polling */ if( keys != 0 ) [ if( OnboardKeyIntEnable == HAL_KEY_INTERRUPT_ENABLE ) [ OnboardKeyIntEnable = HAL_KEY_INTERRUPT_DISABLE; HalKeyConfig( OnboardKeyIntEnable, OnBoard_KeyCallback); ] ] /* If no key is currently pressed down and interrupt is disabled, enable interrupt and turn off polling */ else [ if( OnboardKeyIntEnable == HAL_KEY_INTERRUPT_DISABLE ) [ OnboardKeyIntEnable = HAL_KEY_INTERRUPT_ENABLE; HalKeyConfig( OnboardKeyIntEnable, OnBoard_KeyCallback); ] ] |
827 浏览 1 评论
1071 浏览 0 评论
620 浏览 1 评论
467 浏览 1 评论
662 浏览 2 评论
264浏览 29评论
1225浏览 23评论
356浏览 20评论
334浏览 14评论
200浏览 13评论
GMT+8, 2025-3-6 02:09 , Processed in 1.106977 second(s), Total 58, Slave 49 queries .
