《CC26xx威廉希尔官方网站
参考手册》p.1383:
20.4.4.2 Motorola SPI Frame Format The Motorola SPI interface is a 4-wire interface where the SSIn_FSS signal behaves as a slave select. The main feature of the Motorola SPI format is that the inactive state and phase of the SSIn_CLK signal can be programmed through the SPO and SPH bits in the SSI:CR0 control register. 请问下,意思是不是CC2640的硬件SPI接口只支持4线SPI的设备,不支持3线SPI设备? |
3 个讨论
272 浏览 1 评论
1012 浏览 0 评论
612 浏览 1 评论
458 浏览 1 评论
650 浏览 2 评论
243浏览 29评论
1210浏览 23评论
349浏览 20评论
324浏览 14评论
180浏览 13评论
GMT+8, 2025-2-24 11:25 , Processed in 1.215049 second(s), Total 58, Slave 48 queries .
