特点:
• Single-Supply Operation from +1.8V ~ +5.5V • Rail-to-Rail Input / Output • Gain-Bandwidth Product: 1.8MHz (Typ. @25°C) • Low Input Bias Current: 20pA (Typ. @25°C) • Low Offset Voltage: 30µV (Max. @25°C) • Quiescent Current: 180µA per Amplifier (Typ) • Operating Temperature: -45°C ~ +125°C • Zero Drift: 0.03µV/ o C (Typ) • Embedded RF Anti-EMI Filter • Small Package: GS8551 Available in SOT23-5 and SOP-8 Packages GS8552 Available in MSOP-8 and SOP-8 Packages GS8554 Available in SOP-14 and TSSOP-14 Packages 概述: The GS855X amplifier is single/dual/quad supply, micro-power, zero-drift CMOS operational amplifiers, the amplifiers offer bandwidth of 1.8MHz, rail-to-rail inputs and outputs, and single-supply operation from 1.8V to 5.5V. GS855X uses chopper stabilized technique to provide very low offset voltage (less than 5µV maximum) and near zero drift over temperature. Low quiescent supply current of 180µA per amplifier and very low input bias current of 20pA make the devices an ideal choice for low offset, low power consumption and high impedance applications. The GS855X offers excellent CMRR without the crossover associated with traditional complementary input stages. This design results in superior performance for driving analog-to-digital converters (ADCs) without degradation of differential linearity. The GS8551 is available in SOT23-5 and SOP-8 packages. And the GS8552 is available in MSOP-8 and SOP-8 packages. The GS8554 Quad is available in Green SOP-14 and TSSOP-14 packages. The extended temperature range of -45 o C to +125 o C over all supply voltages offers additional design flexibility. 应用: • Transducer Application • Temperature Measurements • Electronics Scales • Handheld Test Equipment • Battery-Powered Instrumentation 封装: ![]() |
GMT+8, 2024-12-26 05:04 , Processed in 0.424061 second(s), Total 37, Slave 29 queries .
