部分log信息如下:
7.436655] <0>.(3)[302:camerahalserver][Camera-ISP][ISP_release]+ Curr UserCount(1->0), (process, pid, tgid)=(camerahalserver, 302, 302), last user [ 7.436671] <0>.(3)[302:camerahalserver][Camera-ISP][ISP_EnableClock]En(0),g_EnableClkCnt(1) [ 7.501142] <0>.(3)[319:rpmb_svc]RPMB_WRITECOUNTER fail [ 7.520059] <0>.(0)[388:HwBinder:232_1]+Set_BTCVSD_State, state=16 [ 7.521156] <0>.(0)[388:HwBinder:232_1]mtk_pcm_btcvsd_tx_open [ 7.521998] <0>.(0)[388:HwBinder:232_1]mtk_pcm_btcvsd_tx_close [ 7.522763] <0>.(0)[388:HwBinder:232_1]+Set_BTCVSD_State, state=0 [ 7.523693] <0>.(0)[388:HwBinder:232_1]mtk_pcm_btcvsd_tx_open [ 7.524539] <0>.(0)[388:HwBinder:232_1]mtk_pcm_btcvsd_tx_close [ 7.525277] <0>.(0)[388:HwBinder:232_1]+Set_BTCVSD_State, state=0 [ 7.528489] <0>.(0)[388:HwBinder:232_1]Btcvsd_Loopback_Control_Get = 0 [ 7.792661] <1>.(1)[325:mtk_wmtd][WMT-IC][W]mtk_wcn_soc_patch_dwn:wmt_core: patch dwn:0 frag(319, 792) ok [ 7.802927] <3>.(3)[319:rpmb_svc]RPMB_WRITECOUNTER fail [ 7.982720] <2>.(2)[401:bootanimation]Dump cpuinfo [ 8.009016] <1>.(1)[325:mtk_wmtd][WMT-IC][W]mtk_wcn_soc_patch_dwn:wmt_core: patch dwn:0 frag(178, 915) ok [ 8.021307] <0>.(0)[325:mtk_wmtd][WMT-IC][E]mtk_wcn_soc_sw_init(1221):bt_tssi_from_wifi=0, bt_tssi_target=0 [ 8.049872] <0>.(0)[229:main]BOOTPROF: 8049.871095:Zygote:Preload Start [ 8.104628] <1>.(1)[319:rpmb_svc]RPMB_WRITECOUNTER fail [pmic6392_init] Preloader Start.................. [pmic6392_init] PMIC CHIP Code = 0x2092 [pmic6392_init] Debug Status: Reg[0x7A]=0x0 [pmic6392_init] Debug Status: Reg[0x7C]=0x20 pl pmic powerkey Press [pmic6392_init] powerKey = 1 [pmic6392_init] is USB in = 0xB003 [pmic6392_init] Reg[0x11A]=0x7B [pmic6392_init] Reg[0x136]=0x1 [pmic_buck_oc_enable] MT6392_BUCK_OC_CON0 0x258 = 0x6 [pmic_buck_oc_enable] Clear Buck OC Flag, MT6392_BUCK_OC_CON0 0x258 = 0x0 [pmic_buck_oc_enable] Enable Buck OC shutdown function... [pmic_ldo_cali_sw_bonding] Done................... [pmic6392_init] Reg[0x70]=0x52 [auxadc_hw_init] Preloader Start.................. [pmic6392_init] Done................... [PLFM] Init I2C: OK(0) [PLFM] Init PWRAP: OK(0) [PLFM] Init PMIC: OK(0) [PLFM] chip_ver[1] |
是不是EMMC没解锁的问题
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之CSI
372 浏览 0 评论
迅为RK3568开发板篇Openharmony配置HDF控制UART-实操-HDF驱动配置UART-修改HCS配置
822 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之SAI
945 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之ENET
582 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之电阻屏触摸
1037 浏览 0 评论
GMT+8, 2025-2-23 14:17 , Processed in 0.537140 second(s), Total 72, Slave 55 queries .
