A665341.1丝印这个
贴片的IC型号太乱了
有用信息只有“3V升压带功能IC”和“封装SOT23-6 升压恒流”吗?
AL700 封装SOT23-6 输入3-25V恒流模式升压IC AL700,AL702,AL703,AL704,AL705,AL706,AL707,AL708,AL709, AL710,AL712,AL713,AL714,AL715,AL716,AL717,AL718,AL719, AL720,AL722,AL723,AL724,AL725,AL726,AL727,AL728,AL729, AL730,AL732,AL733,AL734,AL735,AL736,AL737,AL738,AL739, AL740,AL742,AL743,AL744,AL745,AL746,AL747,AL748,AL749, AL750,AL752,AL753,AL754,AL755,AL756,AL757,AL758,AL759, AL760,AL762,AL763,AL764,AL765,AL766,AL767,AL768,AL769, AL770,AL772,AL773,AL774,AL775,AL776,AL777,AL778,AL779, AL780,AL782,AL783,AL784,AL785,AL786,AL787,AL788,AL789, AL790,AL792,AL793,AL794,AL795,AL796,AL797,AL798,AL799, 主要性能:恒流模式的PWM升压IC, 适用于锂电池(3~4.2V)输出5V,1A的移动电源应用,工作频率为1MHZ,可以搭配3.3uh小型贴片电感,减少成品体积,内置过温保护,关断保护,欠压保护,过流保护,并可以外接电阻调整电流值(0.5~2.5A) Features Adjustable Output up to 24V Internal Fixed PWM frequency: 1.0MHz Precision Feedback Reference Voltage: 0.6V (±2%) Internal 0.25Ω, 2A, 26V Power MOSFET Shutdown Current: 0.1μA Over Voltage Protection Over Temperature Protection Adjustable Over Current Protection: 0.5A ~ 2.5A Package: SOT23-6L Applications: Chargers, LCD Displays, Digital Cameras, Handheld Devices, Portable Products |
不敢确定,楼主自己参考判断一下。
是个MCU,我们免费开发写好IC
2186 浏览 0 评论
5771 浏览 0 评论
3356 浏览 2 评论
6367 浏览 2 评论
4184 浏览 0 评论
GMT+8, 2024-12-26 00:14 , Processed in 0.605883 second(s), Total 79, Slave 62 queries .
