您好,任何人都可以推荐条形码阅读器用于VEE应用程序。
我更喜欢串口设备,但可以使用USB。此外,任何有关设备软件界面(dll,AXetc)的战争故事都会非常受欢迎。非常感谢安迪------------- |
你好,作为VEE Pro的全新手,我对它的一些功能有几个问题。
我需要连接到MySQL数据库。 我已经在使用ADO的帮助中看到了这个例子,但这看起来像一个非常“笨重”的解决方案。 我是否有更好的方式与SQL数据库进行通信? (写一个dll?othermethods?)2。 作为一个新手,我仍然试图将这种范式从传统节目转变为这种视觉环境。 我一直想做的一件事就是编写几行代码来完成一项特定的任务,而不是拖入十几个盒子并以杂乱的方式加入它们。 我是否有任何方法可以包含短脚本(例如VBscript或其他)来执行简单的处理算法,否则需要使用大量的VEE“块”以及更多的时间来实现?非常感谢,Craig McIntyre .------ -------------------------------------------------- -------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 Hi there, Being a complete newbie to VEE Pro, I have a couple of questions about some of its functionality. 1. I need to interface to a MySQL database. I've seen the example in the help which uses ADO however this looks like a pretty 'clunky' solution. Is there a better way to communicate with an SQL database? (write a dll? other methods?) 2. Being a newbie, I'm still trying to make that paradigm shift from conventional programming into this visual environment. One thing I keep wanting to do is to write a few lines of code to do a particular task instead of dragging in a dozen boxes and joining them up in a messy way. Is there any way to include short scripts (eg VBscript or otherwise) to perform simple processing algorithms that would otherwise require the use of a lot of VEE 'blocks' and a lot more time to implement? Many thanks, Craig McIntyre. --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
很抱歉迟到的回复,我推荐[url = http://www.keepautomation.com/products/net_barcode/]条码网站[/ url],你可以[url = http://www.keepautomation.com/products
/net_barcode_reader/barcode_data_matrix.html]barcode扫描程序[/ url] 以上来自于谷歌翻译 以下为原文 sorry for late reply , i recommend this barcode site where you can the barcode scanners |
1038 浏览 0 评论
2282 浏览 1 评论
2068 浏览 1 评论
1942 浏览 5 评论
2811 浏览 3 评论
806浏览 1评论
591浏览 0评论
687浏览 0评论
2474浏览 0评论
1527浏览 0评论
GMT+8, 2024-9-22 07:19 , Processed in 1.329071 second(s), Total 77, Slave 61 queries .
