#include
#include #define uchar unsigned char #define uint unsigned int //74HC164 ***it CLK=P1^0; // μíμçÆ½μ½¸ßμçƽ±ßÑØ′¥·¢ ***it MOSI=P1^1; // êy¾Yêäèë unsigned char code Tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07, 0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71}; //12òõêyÂë1ü unsigned char DS_data[6]; /***************************************************** oˉêy1|Äü:êyÂë1üé¨ÃèÑóê±×óoˉêy oˉêy1|Äü:Ñóê±1ms ***************************************************/ void delay1ms() { unsigned char i,j; for(i=0;i<10;i++) for(j=0;j<33;j++) ; } void separateData(unsigned long dat) // datÎa6λêy { DS_data[0]=dat%10; DS_data[1]=dat/10%10; DS_data[2]=dat/100%10; DS_data[3]=dat/1000%10; DS_data[4]=dat/10000%10; DS_data[5]=dat/100000%10; } void write_164(unsigned char dat) { unsigned char i; for(i=0;i<8;i++) { CLK=0; if(dat&0x80) MOSI=1; else MOSI=0; CLK=1; dat<<=1; } } void display() { unsigned char i; for(i=0;i<6;i++) { write_164(Tab[DS_data]); P2=0x3f&(~(0x01< delay1ms(); P2=0xff; //êyÂë1üÃe } } main() { separateData(654321); while(1) { display(); } } 拓展并行口电路仿真.zip (76.67 KB ) |
#include
#include #define uchar unsigned char #define uint unsigned int //74HC164 ***it CLK=P1^0; // 低电平到高电平边沿触发 ***it MOSI=P1^1; // 数据输入 unsigned char code Tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07, 0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71}; //共阴数码管 unsigned char DS_data[6]; /***************************************************** 函数功能:数码管扫描延时子函数 函数功能:延时1ms ***************************************************/ void delay1ms() { unsigned char i,j; for(i=0;i<10;i++) for(j=0;j<33;j++) ; } void separateData(unsigned long dat) // dat为6位数 { DS_data[0]=dat%10; DS_data[1]=dat/10%10; DS_data[2]=dat/100%10; DS_data[3]=dat/1000%10; DS_data[4]=dat/10000%10; DS_data[5]=dat/100000%10; } void write_164(unsigned char dat) { unsigned char i; for(i=0;i<8;i++) { CLK=0; if(dat&0x80) MOSI=1; else MOSI=0; CLK=1; dat<<=1; } } void display() { unsigned char i; for(i=0;i<6;i++) { write_164(Tab[DS_data]); P2=0x3f&(~(0x01< delay1ms(); P2=0xff; //数码管灭 } } main() { separateData(654321); while(1) { display(); } } |
楼主真牛,谢谢
2461 浏览 0 评论
3341 浏览 9 评论
3022 浏览 16 评论
3514 浏览 1 评论
9118 浏览 16 评论
1243浏览 3评论
636浏览 2评论
627浏览 2评论
2373浏览 2评论
1936浏览 2评论
GMT+8, 2025-1-24 13:12 , Processed in 1.151564 second(s), Total 79, Slave 60 queries .
