4 个讨论
看名字应该是NOR flash吧,NOR flash没有什么特殊要求,都支持。
Any 16-bit NOR Flash device should work for read-only use. To support bootloader reauthoring, which requires writing to the device, CFI-compliant bottom-boot-block and uniform-boot-block devices should work. Top-boot-block devices may or may not work (vendor dependent due to non-standard CFI implementations). The following is a list of NOR Flash devices that are explicitly supported for reauthoring (writing). Other devices may be supported. • Spansion S29GL016A • Spansion S29AL016M • MXIC MX29LV160T • Spansion S29GL032A • SST SST39LF/VF200A • SST SST39LF/VF400A • SST SST39LF/VF800A http://processors.wiki.ti.com/index.php/Main_Page Think Over Before Asking. http://www.catb.org/~esr/faqs/smart-questions.html#goal |
lifei639156 发表于 2019-10-25 08:15 谢谢您的回答,但是这个手册里为什么还要列出这个明显支持的型号列表呢?还说其他的型号可能支持。谢谢! |
354 浏览 1 评论
547 浏览 2 评论
793 浏览 3 评论
664 浏览 1 评论
1141 浏览 1 评论
88浏览 29评论
338浏览 23评论
262浏览 20评论
215浏览 14评论
69浏览 13评论
GMT+8, 2024-12-29 15:35 , Processed in 0.982782 second(s), Total 50, Slave 44 queries .
