一步一步的硬件调试,看看是卡到哪里了?
* @brief Read a PHY register * @param PHYAddress: PHY device address, is the index of one of supported 32 PHY devices. * This parameter can be one of the following values: 0,..,31 * @param PHYReg: PHY register address, is the index of one of the 32 PHY register. * This parameter can be one of the following values: * @arg PHY_BCR: Transceiver Basic Control Register * @arg PHY_BSR: Transceiver Basic Status Register * @arg PHY_SR : Transceiver Status Register * @arg More PHY register could be read depending on the used PHY * @retval ETH_ERROR: in case of timeout * MAC MIIDR register value: Data read from the selected PHY register (correct read ) */ uint16_t ETH_ReadPHYRegister(uint16_t PHYAddress, uint16_t PHYReg) { uint32_t tmpreg = 0; __IO uint32_t timeout = 0; /* Check the parameters */ assert_param(IS_ETH_PHY_ADDRESS(PHYAddress)); assert_param(IS_ETH_PHY_REG(PHYReg)); /* Get the ETHERNET MACMIIAR value */ tmpreg = ETH->MACMIIAR; /* Keep only the CSR Clock Range CR[2:0] bits value */ tmpreg &= ~MACMIIAR_CR_MASK; /* Prepare the MII address register value */ tmpreg |=(((uint32_t)PHYAddress<<11) & ETH_MACMIIAR_PA); /* Set the PHY device address */ tmpreg |=(((uint32_t)PHYReg<<6) & ETH_MACMIIAR_MR); /* Set the PHY register address */ tmpreg &= ~ETH_MACMIIAR_MW; /* Set the read mode */ tmpreg |= ETH_MACMIIAR_MB; /* Set the MII Busy bit */ /* Write the result value into the MII Address register */ ETH->MACMIIAR = tmpreg; /* Check for the Busy flag */ do { timeout++; tmpreg = ETH->MACMIIAR; } while ((tmpreg & ETH_MACMIIAR_MB) && (timeout < (uint32_t)PHY_READ_TO)); /* Return ERROR in case of timeout */ if(timeout == PHY_READ_TO) { return (uint16_t)ETH_ERROR; } /* Return data register value */ return (uint16_t)(ETH->MACMIIDR); } |
你下载到硬件里,然后一步步调试,按F10,看卡在哪个函数那了。就好找下一步的错误了。。
你用的什么板子,,原因有2个。。第一个是静态id 还是动态的ID,,,宏定义#define LWIP_DHCP 必须置1 第二个就是板子的硬件,,,,你用的什么网络接口,enc28j60还是其他,,,在看看spi初始化引脚配制
2628 浏览 7 评论
2464 浏览 5 评论
3302 浏览 3 评论
2905 浏览 8 评论
2850 浏览 4 评论
757浏览 1评论
978浏览 0评论
1124浏览 0评论
743浏览 0评论
131浏览 0评论
GMT+8, 2025-2-24 08:49 , Processed in 1.117040 second(s), Total 82, Slave 66 queries .
