if /bin/bash /usr/src/lichee/out/sun8iw7p1/linux/common/buildroot/build/host-autoconf-2.65/build-aux/missing --run makeinfo --no-split -I .
-o autoconf.info autoconf.texi; then rc=0; CDPATH="${ZSH_VERSION+.}:" && cd .; else rc=$?; CDPATH="${ZSH_VERSION+.}:" && cd . && $restore $backupdir/* `echo "./autoconf.info" | sed 's|[^/]*$||'`; fi; rm -rf $backupdir; exit $rc conftest.c:14625: must be after `@defmac' to use `@defmacx' Makefile:241: recipe for target 'autoconf.info' failed make[3]: *** [autoconf.info] Error 1 make[3]: Leaving directory '/usr/src/lichee/out/sun8iw7p1/linux/common/buildroot/build/host-autoconf-2.65/doc' Makefile:338: recipe for target 'install-recursive' failed make[2]: *** [install-recursive] Error 1 make[2]: Leaving directory '/usr/src/lichee/out/sun8iw7p1/linux/common/buildroot/build/host-autoconf-2.65' Makefile:653: recipe for target 'install' failed make[1]: *** [install] Error 2 make[1]: Leaving directory '/usr/src/lichee/out/sun8iw7p1/linux/common/buildroot/build/host-autoconf-2.65' package/Makefile.package.in:296: recipe for target '/usr/src/lichee/out/sun8iw7p1/linux/common/buildroot/build/host-autoconf-2.65/.stamp_host_installed' failed make: *** [/usr/src/lichee/out/sun8iw7p1/linux/common/buildroot/build/host-autoconf-2.65/.stamp_host_installed] Error 2 make: Leaving directory '/usr/src/lichee/buildroot' ERROR: build buildroot Failed root@wanglu-All-Series:/usr/src/lichee# 大师们看下,编译linux3.4内核的时候就这个问题解决不了了,是不是那个库没弄好啊 |
9个回答
我就是按照你的走的,你的就显示编译完成了啊,配置是放在那里?
独行客还在吗
我的是ubuntu 14.10,和ubuntu15.04,这个会不会和ubuntu版本有关系啊?
的确不同版本所预置的库不一样,你可以根据出错信息来装需要的库
932 浏览 0 评论
1235 浏览 1 评论
2600 浏览 5 评论
2934 浏览 9 评论
2801 浏览 6 评论
1343浏览 3评论
246浏览 2评论
520浏览 2评论
426浏览 2评论
505浏览 1评论
GMT+8, 2025-2-23 04:28 , Processed in 1.118041 second(s), Total 65, Slave 55 queries .
