当我尝试在8up面板上运行探针选择时,它会启动,在分析了1或2个节点后,它会给我以下错误:选择板“WPAN_R243%1”节点“1%U3-43”的探针是
无法访问,因为它没有可访问的探测位置。 有关详细信息,请参阅详细信息文件中的节点需要更多探针报告。 (警告PBS124)节点“1%U7-3”无法访问,因为它没有可访问的探测位置。 有关详细信息,请参阅详细信息文件中的节点需要更多探针报告。 (警告PBS124)节点“1%U7-5”无法访问,因为它没有可访问的探测位置。 有关详细信息,请参阅详细信息文件中的节点需要更多探针报告。 (警告PBS124)探头选择无法在节点“1%GND”上放置足够的探头。 有关详细信息,请参阅详细信息文件中的节点需要更多探针报告。 (警告PBS77)*发生内部错误119/4/0。 请联系Agilent Technologies。*我检查了GND节点,每块板有3个探头。 谁能告诉我msg的错误是什么意思? 我该怎么解决? 谢谢GeOrGe_GDL 以上来自于谷歌翻译 以下为原文 When I am trying to run probe selection on a 8up panelized boards, it starts and after 1 or 2 nodes has been analyzed it gives me the following error: Selecting probes for board "WPAN_R243%1" Node "1%U3-43" is inaccessible because it has no accessible probing locations. Please see the Nodes Needing More Probes report in the details file for further information. (WARNING PBS124) Node "1%U7-3" is inaccessible because it has no accessible probing locations. Please see the Nodes Needing More Probes report in the details file for further information. (WARNING PBS124) Node "1%U7-5" is inaccessible because it has no accessible probing locations. Please see the Nodes Needing More Probes report in the details file for further information. (WARNING PBS124) Probe Select was not able to put enough probes on node "1%GND". Please see the Nodes Needing More Probes report in the details file for further information. (WARNING PBS77) *Internal error 119/4/0 has occurred. Please contact Agilent Technologies.* I checked the GND node and it has 3 probes per board. could anyone tell me what error msg means? how can I fix it? Thank you GeOrGe_GDL |
嗨乔治,我不认为问题出在您的GND上,只是发生这是错误发生前系统的最后一次输出。
似乎有些东西导致系统崩溃。 错误代码表示“探测选择”进程出错。 你有没有在board和board_xy文件上运行语法检查? 您是否能够使用Fixture Consultant加载电路板而没有任何错误? 你试过在另一个系统上运行吗? 以上来自于谷歌翻译 以下为原文 Hi George, I don't think that the problem is with your GND, it just happens that that was the last output from the system before the error occurs. There seems to be something that is causing your system to crash. The error code means that to the "Probe Select" process has an error. Have you run syntax checking on the board and board_xy files? Are you able to load the board using Fixture Consultant without any error? Have you tried to run on another system? |
1597 浏览 0 评论
2551 浏览 1 评论
2423 浏览 1 评论
2258 浏览 5 评论
3192 浏览 3 评论
1003浏览 0评论
1597浏览 0评论
GMT+8, 2025-7-4 16:05 , Processed in 1.207858 second(s), Total 45, Slave 39 queries .
