注意:如果点击空白处无法输入,则点击字会有输入提示符 | 则可以使用键盘进行输入!
此板块为 [uboot开发]
u-boot-1.1.6_jz2440.patch u-boot-1.1.6.tar.bz2 book@www.100ask.org:/mnt/hgfs/practice/1-2/001$ tar xjf u-boot-1.1.6.tar.bz2 book@www.100ask.org:/mnt/hgfs/practice/1-2/001$ ls u-boot-1.1.6 u-boot-1.1.6_jz2440.patch u-boot-1.1.6.tar.bz2 book@www.100ask.org:/mnt/hgfs/practice/1-2/001$ cd u-boot-1.1.6/ /* 以上是解压缩,过程正常,下面开始打补丁 */ book@www.100ask.org:/mnt/hgfs/practice/1-2/001/u-boot-1.1.6$ patch -p1 < ../u-boot-1.1.6_jz2440.patch patching file board/100ask24x0/100ask24x0.c patching file board/100ask24x0/boot_init.c patching file board/100ask24x0/config.mk patching file board/100ask24x0/flash.c patching file board/100ask24x0/lowlevel_init.S patching file board/100ask24x0/Makefile patching file board/100ask24x0/u-boot.lds patching file board/MAI/bios_emulator/scitech/src/v86bios/lex.l patching file common/cmd_bootm.c patching file common/cmd_load.c patching file common/cmd_menu_bak.c patching file common/cmd_menu.c patching file common/cmd_nand.c patching file common/cmd_nand_legacy.c patching file common/cmd_suspend.c patching file common/cmd_u***slave.c patching file common/env_nand.c patching file common/main.c patching file common/Makefile patching file cpu/ARM920t/cpu.c patching file cpu/arm920t/Makefile patching file cpu/arm920t/s3c24x0/interrupts.c patching file cpu/arm920t/s3c24x0/Makefile patching file cpu/arm920t/s3c24x0/nand_flash.c patching file cpu/arm920t/s3c24x0/nand_flash_legacy.c patching file cpu/arm920t/s3c24x0/speed.c patching file cpu/arm920t/start.S patching file cpu/arm920t/suspend.S patching file doc/README.SBC8560 /* 下面输入y后会报错 */ Reversed (or previously applied) patch detected! Assume -R? [n] y Hunk #1 FAILED at 1. 1 out of 1 hunk FAILED -- saving rejects to file doc# patching file drivers/cfi_flash.c patching file drivers/dm9000x.c patching file drivers/jedec_flash.c patching file drivers/Makefile patching file drivers/nand/nand_base.c patching file drivers/nand/nand_ids.c patching file drivers/nand/nand_util.c patching file drivers/nand_legacy/nand_legacy.c patching file drivers/u***/2440u***.h patching file drivers/u***/Makefile patching file drivers/u***/mrgtmp0 patching file drivers/u***/u***.h patching file drivers/u***/u***in.c patching file drivers/u***/u***in.h patching file drivers/u***/u***init.c patching file drivers/u***/u***init.h patching file drivers/u***/u***lib.c patching file drivers/u***/u***lib.h patching file drivers/u***/u***main.c patching file drivers/u***/u***main.h patching file drivers/u***/u***out.c patching file drivers/u***/u***out.h patching file drivers/u***/u***setup.c patching file drivers/u***/u***setup.h patching file include/asm-arm/mach-types.h patching file include/asm-arm/types.h patching file include/asm-arm/u-boot-arm.h patching file include/configs/100ask24x0.h patching file include/configs/SBC8560.h Reversed (or previously applied) patch detected! Assume -R? [n] y Hunk #1 FAILED at 1. 1 out of 1 hunk FAILED -- saving rejects to file include/configs/SBC8560.h.rej patching file include/def.h patching file include/flash.h patching file include/nand.h patching file include/s3c2410.h patching file include/s3c24x0.h patching file include/u***.h patching file lib_arm/armlinux.c patching file lib_arm/board.c patching file Makefile patching file net/net.c book@www.100ask.org:/mnt/hgfs/practice/1-2/001/u-boot-1.1.6$ 各位老师和大神,求指导,不知道这个错误有什么影响。想弄清楚它。 |
3个回答
换另一个版本的系统试试。
你的文件都是网盘下载的吗 有没有被修改过
197个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2223 浏览 6 评论
2024 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4583 浏览 1 评论
GMT+8, 2025-2-12 14:58 , Processed in 0.482961 second(s), Total 46, Slave 38 queries .
