大家好,我想知道是否有GPIB查询命令让我知道以下直流电源的最大电压和电流额定值?
我在手册中搜索没有运气你的帮助将非常感谢。 E5280 / E5281B,N57xx,662xA问候,Ajay 以上来自于谷歌翻译 以下为原文 Hi all, I would like to know if there are a GPIB query command that would let me know the max voltage and current ratings of the following DC supplies? I searched in the manuals with no luck Your help would be highly appreciated. E5280/E5281B, N57xx, 662xA Regards, Ajay |
3个回答
嗨,Ajay,我不熟悉你提到的第一个型号。
你能仔细检查一下吗? 对于N5700耗材,它是标准的SCPI查询:VOLT? MAX CURR? MAX这些应返回最大可编程值。 662xA是SCPI之前的,它有一个非常简单的编程接口。 唯一可以通过根据型号制作查找表来了解最大值的方法。 谢谢。 马特 以上来自于谷歌翻译 以下为原文 Hi Ajay, I am not familiar with the first model numbers that you mention. Can you double check them? For the N5700 supplies, it is a standard SCPI query: VOLT? MAX CURR? MAX These should return the maximum programmable values. 662xA was pre SCPI and it has a very simple programming interface. The only way you would know what the maximums are is by making a lookup table based on the model number. Thanks. Matt |
嗨马特,谢谢你的回复。 我不知道这些标准查询。 我在N5700系列用户指南中找不到它。(http://cp.literature.agilent.com/litweb/pdf/5969-2917.pdf)E5280B / E5281B是进入E5270B测量主机的HPSMU和MPSMU (http://www.home.agilent.com/sec/product.jspx?nid=-33786.536895055.00&lc=eng&cc=US)。 此致,Ajay 以上来自于谷歌翻译 以下为原文 Hi Matt, Thanks for the reply. I was not aware of these standard queries. I couldn't find it in the N5700 series user guide.(http://cp.literature.agilent.com/litweb/pdf/5969-2917.pdf) E5280B/E5281B are the HPSMU and MPSMU that go into E5270B measurement mainframe (http://www.home.agilent.com/sec/product.jspx?nid=-33786.536895055.00&lc=eng&cc=US). Regards, Ajay |
我工作的安捷伦部分不拥有E5280 / E5281,但我确实得到了他们的答复:“E5270B是E5280B HPSMU或E5281B MPSMU的主机没有获取最大电压或电流的查询命令。
“ 以上来自于谷歌翻译 以下为原文 The part of Agilent that I work for does not own the E5280/E5281 but I do have a response from them: "E5270B which is the mainframe of E5280B HPSMU or E5281B MPSMU doesn't have a query command for getting maximum voltage or current." |
1416 浏览 0 评论
2426 浏览 1 评论
2282 浏览 1 评论
2120 浏览 5 评论
3039 浏览 3 评论
1539浏览 1评论
853浏览 0评论
1301浏览 0评论
1417浏览 0评论
GMT+8, 2025-3-15 02:41 , Processed in 2.396355 second(s), Total 80, Slave 64 queries .
