请问根据Cy7C136的数据手册上描述。
Each port has independent control pins; chip enable (CE),write enable (R/W), and output enable (OE). BUSY flags areprovided on each port. In addition, an interrupt flag (INT) isprovided on each port of the 52-pin PLCC version. BUSY signalsthat the port is trying to access the same location currentlybeing accessed by the other port. On the PLCC version, INTis an interrupt flag indicating that data has been placed in aunique location (7FF for the left port and 7FE for the right port).An automatic power-down feature is controlled independentlyon each port by the chip enable (CE) pins. PLCC系列封装有中断功能,但是没有说明PQFP的封装是否有中断功能,但是查看原理图引脚描述中PQFP封装有中断引脚那么这个PQFP封装的芯片究竟有没有中断功能啊 |
都有的只不过PLCC是双端都有而已
762个成员聚集在这个小组
加入小组2185 浏览 1 评论
1934 浏览 1 评论
3754 浏览 1 评论
1857 浏览 6 评论
1599 浏览 1 评论
959浏览 2评论
661浏览 2评论
511浏览 2评论
478浏览 2评论
1346浏览 2评论
GMT+8, 2025-4-5 09:10 , Processed in 0.833394 second(s), Total 47, Slave 41 queries .
