5 个讨论
The EasyLink API should be used in application code. The EasyLink API is intended to abstract the RF Driver in order to give a simple API for customers to use as is or extend to suit their application[Use Cases]
The SimpleLink MCU SDKs feature common components and device-specific middleware to speed up your time-to-market and provide a unified development experience across the entire SimpleLink MCU portfolio of wired and wireless devices. Intuitive and standardized APIs enable 100% application code portability. |
uuwufydsw 发表于 2019-9-17 09:04 Hi, Eggsy Pang, 感谢您的回答。 是否可以理解为EasyLink是在RF基础上封装的一对API函数,如果要实现433MHz通信,在RF Packet或EasyLink例程基础上开发,实现的最终效果(如点对点通信、星状通信等)是一样的? 还是说EasyLink提供的API函数更全面、更容易实现呢? 问题貌似比较傻,望见谅。希望得到回答。 |
个人用户 发表于 2019-9-17 08:58 Hi, Felix ZF, 感谢您的回答。 |
544 浏览 1 评论
393 浏览 1 评论
589 浏览 2 评论
844 浏览 3 评论
691 浏览 1 评论
148浏览 29评论
788浏览 23评论
297浏览 20评论
253浏览 14评论
102浏览 13评论
GMT+8, 2025-1-14 11:57 , Processed in 0.900435 second(s), Total 49, Slave 43 queries .
