GPIO_InitStructure.GPIO_Pin = LCD_GPIO_LED_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(LCD_GPIO_LED_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = LCD_GPIO_DATA_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(LCD_GPIO_DATA_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = LCD_GPIO_CS_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(LCD_GPIO_CS_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = LCD_GPIO_RS_PIN; GPIO_Init(LCD_GPIO_RS_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = LCD_GPIO_NWR_PIN; GPIO_Init(LCD_GPIO_NWR_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = LCD_GPIO_RD_PIN; GPIO_Init(LCD_GPIO_RD_PORT, &GPIO_InitStructure); 请问原子哥程序中后面3个IO口这样写,也是和红色字体中一样设置那个3个IO口为推挽输出模式吗? |
会一直保存下去,直到你改变为止. 所以这里我认为只要设置一次就OK了.后面两次都是多余的. |
明白了 谢谢原子哥
1932 浏览 1 评论
1705 浏览 1 评论
1185 浏览 2 评论
785 浏览 2 评论
1750 浏览 2 评论
1992浏览 9评论
827浏览 4评论
279浏览 3评论
637浏览 3评论
644浏览 3评论
GMT+8, 2025-2-2 17:56 , Processed in 1.082697 second(s), Total 77, Slave 61 queries .
