嗨约翰,见功能&
对象浏览器,VEE对象。 有一个条目'XYDevice',成员包括标记操作。 用你的图表名称(rclick - > properties)替换'XYDevice',就在标题下面。 范围是上下文的本地。抓取graph.marker1并在用户按下按钮时将其设置为变量。 重新调用时重新调用var并调用graph.marker1 = ...那就要做了.BR,AnttiFrom:John Wing [mailto:jwing@psemc.com]发送时间:2005年9月22日23:12To:VRFS主题:[vrf] pre- 位置标记是否可以预先定位XY轨迹的标记?我有一个程序,操作员手动将标记放在XY轨迹上然后点击一个按钮,根据标记的位置进行一些计算。 重新显示XY跟踪,但标记重新出现在默认位置。 是否有可能让标记出现在操作员在重新显示痕迹之前放置的位置?John ------------------------- - 以上来自于谷歌翻译 以下为原文 Hi John, See the function & object browser, VEE Objects. There's a entry 'XYDevice', members include marker manipulations. Substitute 'XYDevice' with your graph's Name (rclick-->properties), just below title. Scope is local to context. Grab the graph.marker1 and set it to variable when user presses the button. Recall the var when redisplaying and call graph.marker1=... That oughta do it. BR,AnttiFrom: John Wing [mailto:jwing@psemc.com] Sent: 22 September 2005 23:12To: VRFSubject: [vrf] pre-position markersIs it possible to preposition the markers of a XY Trace?I have a program where the operator manually places the markers on the XY Trace then hits a button that does some calculations based on the position of the of the markers. The XY Trace is redisplayed but the markers reappear in a default position. Is it possible to have the markers appear in the same location the operator placed them prior to the redisplay of the trace? John----------------------------------------------------------------Please note: This e-mail may contain privileged and confidentialinformation and is intended solely for the addressee. If you arenot the intended recipient or an employee responsible fordelivering this message to the intended recipient, you arehereby notified that any review, publication, dissemination,distribution, copying or use of the information in this messageis strictly prohibited. If you have received this e-mail byerror, please notify the sender immediately by replying to themessage and subsequently delete it from your system.E-mail is susceptible to data corruption, interception,unauthorized amendment, tampering and viruses. We only send andreceive e-mail messages on the basis that we are not liable forany such corruption, interception, amendment, tampering,viruses, any other reprehensible acts or any consequences ofthe aforementioned.---You are currently subscribed to vrf as: r***@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
5个回答
重新显示XY跟踪,但标记重新出现在默认位置。 在重新显示跟踪之前,是否可以将标记显示在操作员放置的相同位置?John ---您目前订阅vrf为:r***@soco.agilent.com要订阅,请发送空白电子邮件至“ join-vrf@it.lists.it.agilent.com“。要取消订阅,请发送一封空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件到此邮件列表,请发送电子邮件至”vrf @“ agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Is it possible to preposition the markers of a XY Trace?I have a program where the operator manually places the markers on the XY Trace then hits a button that does some calculations based on the position of the of the markers. The XY Trace is redisplayed but the markers reappear in a default position. Is it possible to have the markers appear in the same location the operator placed them prior to the redisplay of the trace? John---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
嗨约翰,见功能&
对象浏览器,VEE对象。 有一个条目'XYDevice',成员包括标记操作。 用你的图表名称(rclick - > properties)替换'XYDevice',就在标题下面。 范围是上下文的本地。抓取graph.marker1并在用户按下按钮时将其设置为变量。 重新调用时重新调用var并调用graph.marker1 = ...那就要做了.BR,AnttiFrom:John Wing [mailto:jwing@psemc.com]发送时间:2005年9月22日23:12To:VRFS主题:[vrf] pre- 位置标记是否可以预先定位XY轨迹的标记?我有一个程序,操作员手动将标记放在XY轨迹上然后点击一个按钮,根据标记的位置进行一些计算。 重新显示XY跟踪,但标记重新出现在默认位置。 是否有可能让标记出现在操作员在重新显示痕迹之前放置的位置?John ------------------------- ---------------------------------------请注意:此电子邮件可能包含特权和 保密信息,仅供收件人使用。 如果您不是预期的收件人或负责向目标收件人发送此邮件的员工,则会通知您严格禁止对此邮件中的信息进行任何审查,发布,传播,分发,复制或使用。 如果您收到此电子邮件,请立即通过回复themessage通知发件人,然后将其从您的系统中删除。电子邮件容易受到数据损坏,拦截,未经授权的修改,篡改和病毒的侵害。 我们只发送和接收电子邮件,因为我们不对此类腐败,拦截,修改,篡改,病毒,任何其他应受谴责的行为或上述任何后果负责.---您目前订阅了vrf:r*** @ soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com” 。要发送邮件到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Hi John, See the function & object browser, VEE Objects. There's a entry 'XYDevice', members include marker manipulations. Substitute 'XYDevice' with your graph's Name (rclick-->properties), just below title. Scope is local to context. Grab the graph.marker1 and set it to variable when user presses the button. Recall the var when redisplaying and call graph.marker1=... That oughta do it. BR,AnttiFrom: John Wing [mailto:jwing@psemc.com] Sent: 22 September 2005 23:12To: VRFSubject: [vrf] pre-position markersIs it possible to preposition the markers of a XY Trace?I have a program where the operator manually places the markers on the XY Trace then hits a button that does some calculations based on the position of the of the markers. The XY Trace is redisplayed but the markers reappear in a default position. Is it possible to have the markers appear in the same location the operator placed them prior to the redisplay of the trace? John----------------------------------------------------------------Please note: This e-mail may contain privileged and confidentialinformation and is intended solely for the addressee. If you arenot the intended recipient or an employee responsible fordelivering this message to the intended recipient, you arehereby notified that any review, publication, dissemination,distribution, copying or use of the information in this messageis strictly prohibited. If you have received this e-mail byerror, please notify the sender immediately by replying to themessage and subsequently delete it from your system.E-mail is susceptible to data corruption, interception,unauthorized amendment, tampering and viruses. We only send andreceive e-mail messages on the basis that we are not liable forany such corruption, interception, amendment, tampering,viruses, any other reprehensible acts or any consequences ofthe aforementioned.---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
嗨约翰,见功能&
对象浏览器,VEE对象。 有一个条目'XYDevice',成员包括标记操作。 用你的图表名称(rclick - > properties)替换'XYDevice',就在标题下面。 范围是上下文的本地。抓取graph.marker1并在用户按下按钮时将其设置为变量。 重新显示当回想var和调用graph.marker1 = ...那现在应该做it.BR,AnttiFrom:永翼[邮寄地址:jwing@psemc.com]发送时间:2005年23年9月22日:12要:VRFSubject:[VRF]预 位置标记是否可以预先定位XY轨迹的标记?我有一个程序,操作员手动将标记放在XY轨迹上然后点击一个按钮,根据标记的位置进行一些计算。 重新显示XY跟踪,但标记重新出现在默认位置。 是否有可能让标记出现在操作员在重新显示痕迹之前放置的位置?John ------------------------- ---------------------------------------请注意:此电子邮件可能包含特权和 保密信息,仅供收件人使用。 如果您不是预期的收件人或负责向目标收件人发送此邮件的员工,则会通知您严格禁止对此邮件中的信息进行任何审查,发布,传播,分发,复制或使用。 如果您收到此电子邮件,请立即通过回复themessage通知发件人,然后将其从您的系统中删除。电子邮件容易受到数据损坏,拦截,未经授权的修改,篡改和病毒的侵害。 我们只发送和接收电子邮件,因为我们不对此类腐败,拦截,修改,篡改,病毒,任何其他应受谴责的行为或上述任何后果负责.---您目前订阅了vrf:r*** @ soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com” 。要发送邮件到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Hi John, See the function & object browser, VEE Objects. There's a entry 'XYDevice', members include marker manipulations. Substitute 'XYDevice' with your graph's Name (rclick-->properties), just below title. Scope is local to context. Grab the graph.marker1 and set it to variable when user presses the button. Recall the var when redisplaying and call graph.marker1=... That oughta do it. BR,AnttiFrom: John Wing [mailto:jwing@psemc.com] Sent: 22 September 2005 23:12To: VRFSubject: [vrf] pre-position markersIs it possible to preposition the markers of a XY Trace?I have a program where the operator manually places the markers on the XY Trace then hits a button that does some calculations based on the position of the of the markers. The XY Trace is redisplayed but the markers reappear in a default position. Is it possible to have the markers appear in the same location the operator placed them prior to the redisplay of the trace? John----------------------------------------------------------------Please note: This e-mail may contain privileged and confidentialinformation and is intended solely for the addressee. If you arenot the intended recipient or an employee responsible fordelivering this message to the intended recipient, you arehereby notified that any review, publication, dissemination,distribution, copying or use of the information in this messageis strictly prohibited. If you have received this e-mail byerror, please notify the sender immediately by replying to themessage and subsequently delete it from your system.E-mail is susceptible to data corruption, interception,unauthorized amendment, tampering and viruses. We only send andreceive e-mail messages on the basis that we are not liable forany such corruption, interception, amendment, tampering,viruses, any other reprehensible acts or any consequences ofthe aforementioned.---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
1299 浏览 0 评论
2379 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1146浏览 1评论
760浏览 0评论
953浏览 0评论
1299浏览 0评论
GMT+8, 2024-12-29 23:14 , Processed in 1.495020 second(s), Total 51, Slave 45 queries .
