3 个讨论
看外设驱动库的源码嘛: void SSIDataGet(uint32_t ui32Base, uint32_t *pui32Data) [ // // Check the arguments. // ASSERT(_SSIBaseValid(ui32Base)); // // Wait until there is data to be read. // while(!(HWREG(ui32Base + SSI_O_SR) & SSI_SR_RNE)) [ ] // // Read data from SSI. // *pui32Data = HWREG(ui32Base + SSI_O_DR); ] void SSIDataPut(uint32_t ui32Base, uint32_t ui32Data) [ // // Check the arguments. // ASSERT(_SSIBaseValid(ui32Base)); ASSERT((ui32Data & (0xfffffffe << (HWREG(ui32Base + SSI_O_CR0) & SSI_CR0_DSS_M))) == 0); // // Wait until there is space. // while(!(HWREG(ui32Base + SSI_O_SR) & SSI_SR_TNF)) [ ] // // Write the data to the SSI. // HWREG(ui32Base + SSI_O_DR) = ui32Data; ] |
224 浏览 1 评论
1010 浏览 0 评论
612 浏览 1 评论
458 浏览 1 评论
650 浏览 2 评论
240浏览 29评论
1210浏览 23评论
349浏览 20评论
324浏览 14评论
180浏览 13评论
GMT+8, 2025-2-24 05:40 , Processed in 0.748441 second(s), Total 47, Slave 40 queries .
