最近在看llwip基于arp部分实现源码,想咨询下LWIP关于其ip数据包发送局域网外单播包的一点疑惑?就是lwip如果发现是非本地单播包会将发送的目的ip改为网关ip,那么我的疑惑是发给网关之后,那么网关是怎么知道数据是要发给谁的?小弟拜谢了
//ip层包的发送是借助etharp_output()接口实现,单播包会调用etharp_query()给指定的ip地址处发送ip数据包或arp请求,下面是etharp_output()部分代码 err_t etharp_output(struct netif *netif, struct pbuf *q, ip_addr_t *ipaddr) { struct eth_addr *dest; struct eth_addr mcastaddr; ip_addr_t *dst_addr = ipaddr; LWIP_ASSERT("netif != NULL", netif != NULL); LWIP_ASSERT("q != NULL", q != NULL); LWIP_ASSERT("ipaddr != NULL", ipaddr != NULL); /* make room for Ethernet header - should not fail */ if (pbuf_header(q, sizeof(struct eth_hdr)) != 0) { /* bail out */ LWIP_DEBUGF(ETHARP_DEBUG | LWIP_DBG_TRACE | LWIP_DBG_LEVEL_SERIOUS, ("etharp_output: could not allocate room for header.n")); LINK_STATS_INC(link.lenerr); return ERR_BUF; } /* Determine on destination hardware address. Broadcasts and multicasts * are special, other IP addresses are looked up in the ARP table. */ /* broadcast destination IP address? */ if (ip_addr_i***roadcast(ipaddr, netif)) { /* broadcast on Ethernet also */ dest = (struct eth_addr *)ðbroadcast; /* multicast destination IP address? */ } else if (ip_addr_ismulticast(ipaddr)) { /* Hash IP multicast address to MAC address.*/ mcastaddr.addr[0] = LL_MULTICAST_ADDR_0; mcastaddr.addr[1] = LL_MULTICAST_ADDR_1; mcastaddr.addr[2] = LL_MULTICAST_ADDR_2; mcastaddr.addr[3] = ip4_addr2(ipaddr) & 0x7f; mcastaddr.addr[4] = ip4_addr3(ipaddr); mcastaddr.addr[5] = ip4_addr4(ipaddr); /* destination Ethernet address is multicast */ dest = &mcastaddr; /* unicast destination IP address? */ } else { s8_t i; /* outside local network? if so, this can neither be a global broadcast nor a subnet broadcast. */ if (!ip_addr_netcmp(ipaddr, &(netif->ip_addr), &(netif->netmask)) && !ip_addr_islinklocal(ipaddr)) { #if LWIP_AUTOIP struct ip_hdr *iphdr = (struct ip_hdr*)((u8_t*)q->payload + sizeof(struct eth_hdr)); /* According to RFC 3297, chapter 2.6.2 (Forwarding Rules), a packet with a link-local source address must always be "directly to its destination on the same physical link. The host MUST NOT send the packet to any router for forwarding". */ if (!ip_addr_islinklocal(&iphdr->src)) #endif /* LWIP_AUTOIP */ { /* interface has default gateway? */ if (!ip_addr_isany(&netif->gw)) { /* send to hardware address of default gateway IP address */ dst_addr = &(netif->gw); //这部分将i局域网外目的ip地址设置为网关ip, /* no default gateway available */ } else { /* no route to destination error (default gateway missing) */ return ERR_RTE; } } } #if LWIP_NETIF_HWADDRHINT if (netif->addr_hint != NULL) { /* per-PCB cached entry was given */ u8_t etharp_cached_entry = *(netif->addr_hint); if (etharp_cached_entry < ARP_TABLE_SIZE) { #endif /* LWIP_NETIF_HWADDRHINT */ if ((arp_table[etharp_cached_entry].state >= ETHARP_STATE_STABLE) && (ip_addr_cmp(dst_addr, &arp_table[etharp_cached_entry].ipaddr))) { /* the per-pcb-cached entry is stable and the right one! */ ETHARP_STATS_INC(etharp.cachehit); return etharp_output_to_arp_index(netif, q, etharp_cached_entry); } #if LWIP_NETIF_HWADDRHINT } } #endif /* LWIP_NETIF_HWADDRHINT */ /* find stable entry: do this here since this is a critical path for throughput and etharp_find_entry() is kind of slow */ for (i = 0; i < ARP_TABLE_SIZE; i++) { if ((arp_table.state >= ETHARP_STATE_STABLE) && (ip_addr_cmp(dst_addr, &arp_table.ipaddr))) { /* found an existing, stable entry */ ETHARP_SET_HINT(netif, i); return etharp_output_to_arp_index(netif, q, i); } } /* no stable entry found, use the (slower) query function: queue on destination Ethernet address belonging to ipaddr */ return etharp_query(netif, dst_addr, q); //单播包会调用etharp_query()实现单播包发送,那么网关怎么知道收到的数据包是发给谁的?如何转发的呢? } /* continuation for multicast/broadcast destinations */ /* obtain source Ethernet address of the given interface */ /* send packet directly on the link */ return etharp_send_ip(netif, q, (struct eth_addr*)(netif->hwaddr), dest); } |
2628 浏览 7 评论
2464 浏览 5 评论
3302 浏览 3 评论
2905 浏览 8 评论
2850 浏览 4 评论
757浏览 1评论
979浏览 0评论
1124浏览 0评论
743浏览 0评论
156浏览 0评论
GMT+8, 2025-2-24 15:50 , Processed in 1.098430 second(s), Total 75, Slave 59 queries .
