亲爱的先生:当我购买网络分析仪(8753C)时,我的网络分析仪附带了一个EEPROM备份磁盘(软盘)。
当我尝试在基于Windows O / S的环境中查看磁盘时,Windows无法读取磁盘。 它甚至无法告诉我磁盘上有哪些文件。 Windows一直要求我格式化磁盘。 我希望我的磁盘没有损坏或损坏。 由于磁盘非常老 - 这台NA在其“鼎盛时期”之前,台式电脑成为一个集成单元(惠普出售单独的磁盘驱动器,HP9122,用于其电脑),我希望我之所以无法阅读 磁盘是因为文件格式可能与Windows环境不兼容。 你能告诉我典型的EEPROM磁盘(* .LIF?或其他)上的文件类型吗?Windows实际上可以读取磁盘上的文件名(我发现这个问题对于一个人来说可能看起来很简单 谁先前可以访问许多NA EEPROM软盘,但我无法从我的磁盘读取,因此,我无法确定磁盘上的文件类型是什么,我无法访问各种NA EEPROM软盘 )。 另外,你能告诉我是否有一种方法可以确定磁盘是否良好而无需外出购买旧磁盘驱动器? 我可以访问8753D NA,它有一个内置的磁盘驱动器。 我可以使用此磁盘驱动器来确定我的磁盘是否仍然良好? 如果答案是肯定的,你能否告诉我一些我将在磁盘上看到的文件名,如果8753D可以从8753C EEPROM磁盘读取(这只是一个检查,以便我知道这个方法一切正常) ? 感谢您过去的回复,我期待着您的下一个回复。 编辑:SOLT_guy于2012年4月28日下午10:21编辑:SOLT_guy于2012年4月29日1:01 PM编辑:SOLT_guy于2012年4月29日下午1:07 以上来自于谷歌翻译 以下为原文 Dear Sir: When I bought my network analyzer (8753C) an EEPROM back up disk (floppy disk) was shipped with my network analyzer. When I attempt to look at the disk in a Windows O/S based environment, Windows cannot read the disk. It can't even tell me what files are on the disk. Windows keeps requesting that I format the disk. I am hoping that my disk is not damaged or corrupted. Since the disk is very old - this NA was in its "heyday" before the desktop PC became an integretated unit (HP sold separate disk drives, HP9122, for its computers), I am hoping that the reason why I can't read from the disk is because the file format may be incompatible with the Windows environment. Can you tell me the file types that are on a typical EEPROM disk (*.LIF ? or other) and can Windows actually read the filenames that are on the disk (I realize that this question may appear to be simple to answer for a person who has had prior access to many NA EEPROM floppy disks but I can't read from my disk, therefore, I have no way of being certain what file types are on the disk and I don't have access to various NA EEPROM floppy disks). Also, can you tell me if there is a way I can determine if the disk is good without having to go out and buy an old disk drive? I have access to a 8753D NA which has a built in disk drive. Can I use this disk drive to determine if my disk is still good? If the answer is yes, can you tell me some of the filenames that I will see on the disk, if the 8753D can read from the 8753C EEPROM disk (this is just a check so that I know that everything is OK with this method)? Thank you for your past replies and I look forward to reading your next reply. Edited by: SOLT_guy on Apr 28, 2012 10:21 PM Edited by: SOLT_guy on Apr 29, 2012 1:01 PM Edited by: SOLT_guy on Apr 29, 2012 1:07 PM |
这几乎可以肯定是LIF格式的光盘。
有一些例程可以在PC上使用LIF-to-DOS实用程序来读取它,但我认为你需要Win98或更早版本才能使用它。 我现在还不知道还有什么。 有些乐器可以读取这两种格式......例如8711系列......但我不确定哪个版本......可能是C版本。 以上来自于谷歌翻译 以下为原文 This is almost certainly a LIF formatted disc. There were routines to read this on a PC using a LIF-to-DOS utility, but I think you needed Win98 or earlier to use it. I do not know what else is out there now. Some instruments could read both formats...such as the 8711 family...but I am not sure which versions...probably the C versions. |
胡bbs2 发表于 2019-8-20 11:43 亲爱的JVALL; 感谢您的反馈意见。 我想这会结束讨论,除非别人有其他东西需要补充。 我感谢您的信息。 再次感谢你。 以上来自于谷歌翻译 以下为原文 Dear JVALL; Thank you for your feedback. I guess this closes out the discussion unless someone else has something else to add. I appreciate your information. Thank you, again. |
1210 浏览 0 评论
2344 浏览 1 评论
2145 浏览 1 评论
2017 浏览 5 评论
2897 浏览 3 评论
945浏览 1评论
689浏览 0评论
792浏览 0评论
1210浏览 0评论
GMT+8, 2024-11-15 07:16 , Processed in 1.317590 second(s), Total 80, Slave 64 queries .
