调试环境:
我使用TMS320C5515 eZdsp USB Stick dsp单板,这个单板带有一个tlv320aic3204音频芯片; 目标: 我希望可以播放位速128kbps 音频采样大小 16位, 单声道,音频采用级别8kHz,音频格式为pcm的音频文件: 参考: 根据手册上的说明,要使用Mono方式,I2s需要使用DSP format.才有效,我将I2SSCTRL的FRMT置为1,这时就不能接收到音频信号,置为0则可以接收到音频信号。 问题: 请问tlv320aic3204 是否支持单音方式,能否提供参考配置,谢谢! 具体配置: void aic3204_init_mono(void) [ Uint16 regaddr; SYS_EXBUSSEL = 0x6100; // Enable I2C bus USBSTK5515_I2C_init( ); // Initialize I2C /* Configure AIC3204 */ AIC3204_rset( 0, 0 ); // Select page 0 AIC3204_rset( 1, 1 ); // Reset codec USBSTK5515_wait( 500 ); // Wait AIC3204_rset( 0, 1 ); // Point to page 1 AIC3204_rset( 1, 8 ); // Disabled weak connection of AVDD with DVDD AIC3204_rset( 2, 1 ); // Enable Analog Blocks, use LDO power (is LDO power being used? If it is, then this register needs to be set correclty to use LDO). /* PLL and Clocks config and Power Up */ AIC3204_rset( 0, 0 ); // Select page 0 AIC3204_rset( 27, 0x4d ); // BCLK and WCLK is set as output from AIC3204(Master) 00: Audio Interface = dsp AIC3204_rset( 28, 0x00 ); // Data ofset = 0 AIC3204_rset( 4, 3 ); // PLL setting: PLLCLK <- MCLK, CODEC_CLKIN <-PLL CLK AIC3204_rset( 6, 8 ); // **PLL setting: J=8 (comment does not match) AIC3204_rset( 7, 0x07 ); // PLL setting: HI_BYTE(D) AIC3204_rset( 8, 0x80); // PLL setting: LO_BYTE(D) AIC3204_rset( 30, 0x80 ); // For 32 bit clocks per frame in Master mode ONLY (make sure that BCLK >= [ (# bits per channel) * 2 ] // BCLK=DAC_CLK/N =(12288000/8) = 1.536MHz = 32*fs // For 8 KHz sampling AIC3204_rset( 5, 0x91 ); // PLL setting: Power up PLL, P=1 and R=1 AIC3204_rset( 13, 0x01 ); // Hi_Byte(DOSR) for DOSR = 256 decimal or 0x01080 DAC oversamppling AIC3204_rset( 14, 0x00 ); // Lo_Byte(DOSR) for DOSR = 256 decimal or 0x0100 AIC3204_rset( 20, 0x00 ); // AOSR for AOSR = 256 decimal or 0x0000 for decimation filters 1 to 6 AIC3204_rset( 11, 0x86 ); // Power up NDAC and set NDAC value to 3 (comments below differ from the values) AIC3204_rset( 12, 0x88); // Power up MDAC and set MDAC value to 8 (comments below differ from the values) AIC3204_rset( 18, 0x88 ); // Power up NADC and set NADC value to 8 (comments below differ from the values) AIC3204_rset( 19, 0x86 ); // Power up MADC and set MADC value to 6 (comments below differ from the values) AIC3204_rset( 60, 0x19 ); // Power up PRB_P25 for beep generator Selects the ADC (recording) signal processing block AIC3204_rset( 61, 0x01 ); // ADC Singal Processing Block PRB_R1 ADC Signal Processing Block Control Register AIC3204_rset( 48, 0xff ); // Power up MADC and set MADC value to 6 (comments below differ from the values) AIC3204_rset( 49, 0xff ); // Power up PRB_P25 for beep generator /* DAC ROUTING and Power Up */ AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 12, 0x08 ); // LDAC AFIR routed to HPL AIC3204_rset( 13, 0x08 ); // RDAC AFIR routed to HPR &&&&&&& AIC3204_rset( 14, 0x00 ); // Right Channel DAC reconstruction filter's negative terminal is not routed to LOL AIC3204_rset( 15, 0x00 ); // Right Channel DAC reconstruction filter output is not routed to LOR AIC3204_rset( 0, 0x00 ); // Select page 0 AIC3204_rset( 64, 0x02 ); // Left vol=right vol AIC3204_rset( 65, 0x00 ); // Left DAC gain to 0dB VOL; Right tracks Left AIC3204_rset( 66, 0x81 ); // right mute AIC3204_rset( 63, 0xd4 ); // Power up left,right data paths and set channel AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 20, 0x69 ); // Soft Step, De-pop, 6 time constants, 6k ohm. AIC3204_rset( 16, 0x1d ); // Unmute HPL , 29dB gain AIC3204_rset( 17, 0x3a ); // Unmute HPR , -6dB gain AIC3204_rset( 9, 0x30 ); // Power up HPL,HPR AIC3204_rset( 10, 0x33 ); // HP powered from LDOIN, CM voltage = 1.65V AIC3204_rset( 0, 0x00 ); // Select page 0 USBSTK5515_wait( 500 ); // Wait AIC3204_rset( 16, 15 ); // Unmute HPL set gain AIC3204_rset( 17, 00 ); // Unmute HPR set gain /* ADC ROUTING and Power Up */ AIC3204_rset( 0, 1 ); // Select page 1 //AIC3204_rset( 51, 0x40 ); // Mic Bias ON AIC3204_rset( 52, 0x10 ); //IN2L is routed to Left MICPGA with 40K resistance AIC3204_rset( 55, 0x00 ); //IN2R is not routed to Right MICPGA AIC3204_rset( 54, 0x03 ); // CM is routed to Left MICPGA via CM2L with 40K resistance AIC3204_rset( 57, 0x00 ); // CM is not routed to Right MICPGA AIC3204_rset( 59, 0x80 ); // MIC_PGA_L unmute AIC3204_rset( 60, 0x80 ); // MIC_PGA_R unmute AIC3204_rset( 0, 0 ); // Select page 0 AIC3204_rset( 81, 0xa0 ); // Powerup Left and Right ADC AIC3204_rset( 82, 0x04 ); // Unmute Left and Right ADC // I2S settings I2S0_SRGR = 0x0; //I2Sn Sample Rate Generator Register slave mode is invalide I2S0_CR = 0x9011; // 16-bit word, slave, enable I2C Mono mode //I2S2_CR = 0x9811; //I2S0_CR = 0x8010; // I2S0_CR Address: 0x2800 ((I2S BUS) I2Sn Serializer Control Register (I2SSCTRL) // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // |15:14:13:12|11:10: 9: 8| 7: 6: 5: 4| 3: 2: 1: 0| <<== Bit Position // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // |rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw| <<== Read / Write Access // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // | 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| <<== Reset Values // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // | 1 0: 0: 1| 0: 0: 0: 0| 0: 0: 0: 1| 0: 0: 0: 1| <<== current Values // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // | | | | | | | | | | | | | | | | // | | | | | | | | | | | | | | | +-- [0] FRMT (0:I2S/left-justified format, 1:DSP format) // | | | | | | | | | | | | | | +----- [1] MODE (0:Serializer is configured as a slave, 1:master) // | | | | | | | | | | | | | +-------- [2] WDLNGTH (0:clk active, 1:clk disabled) // | | | | | | | | | | | | +----------- [3] WDLNGTH Choose serializer word length 8 10 .. 32 // | | | | | | | | | | | | // | | | | | | | | | | | +-------------- [4] WDLNGTH // | | | | | | | | | | +----------------- [5] WDLNGTH // | | | | | | | | | +-------------------- [6] SIGN_EXT (0:No sign extension, 1:Received data is sign extended. Transmit data is expected to be sign extended.For more information about sign extension) // | | | | | | | | +----------------------- [7] PACK (0:Data packing mode disabled, 1:Data packing mode enabled) // | | | | | | | | // | | | | | | | +-------------------------- [8] DATADLY (0:1-bit data delay, 1:2-bit data delay) // | | | | | | +----------------------------- [9] CLKPOL (0:Controls I2S clock polarity, 1:.....XXX $$$ ) // | | | | | +-------------------------------- [10] FSPOL (0:Inverts I2S frame-synchronization polarity, 1:....XXX $$$) // | | | | +----------------------------------- [11] LOOPBACK (0:Normal operation, no loopback, 1:Digital Loopback mode enabled) // | | | | // | | | +-------------------------------------- [12] MONO (0:Stereo mode, 1:Mono mode. Valid only when bit 0, FRMT=1 (DSP Format)) // | | +----------------------------------------- [13] Reserved // | +-------------------------------------------- [14] Reserved // +----------------------------------------------- [15] ENABLE (0:I2S disabled, 1:I2S enabled) I2S0_ICMR = 0x17; // Enable interrupts //I2S0_ICMR = 0x3f; // I2SINTMASK Address: 0x2814 ((I2S BUS) I2Sn Interrupt Mask Register (I2SINTMASK) // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // |15:14:13:12|11:10: 9: 8| 7: 6: 5: 4| 3: 2: 1: 0| <<== Bit Position // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // |rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw| <<== Read / Write Access // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // | 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| <<== Reset Values // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // | 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 1| 0: 1: 0: 0| <<== current Values // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // | | | | | | | | | | | | | | | | // | | | | | | | | | | | | | | | +-- [0] OUERR (0:Disable overrun/underrun error interrupt, 1:Enable overrun/underrun error interrupt.) // | | | | | | | | | | | | | | +----- [1] FERR (0:Disable frame-synchronization error interrupt, 1:Enable frame-synchronization error interrupt.) // | | | | | | | | | | | | | +-------- [2] RCVMON (0:Disable mono RX data interrupt, 1:Enable mono RX data interrupt.) // | | | | | | | | | | | | +----------- [3] RCVST (0:Disable stereo RX data interrupt, 1:Enable stereo RX data interrupt) // | | | | | | | | // | | | | | | | | | | | | // | | | | | | | | | | | +-------------- [4] XMITMON (0:Disable mono TX data interrupt, 1:Enable mono TX data interrupt) // | | | | | | | | | | +----------------- [5] XMITST (0:Disable stereo TX data interrupt, 1:Enable stereo TX data interrupt) // | | | | | | | | | +-------------------- [6] Reserved // | | | | | | | | +----------------------- [7] Reserved // | | | | | | | | // | | | | | | | +-------------------------- [8] Reserved // | | | | | | +----------------------------- [9] Reserved // | | | | | +-------------------------------- [10] Reserved // | | | | +----------------------------------- [11] Reserved // | | | | // | | | +-------------------------------------- [12] Reserved // | | +----------------------------------------- [13] Reserved // | +-------------------------------------------- [14] Reserved // +----------------------------------------------- [15] Reserved ] |
4 个讨论
qwe041 发表于 2019-8-14 16:13 HPL有一个很奇怪的问题,就是前文中我提到的耳机中听到的pc播放的声音,我把IN1L,MAL,LDAC,MAR都关闭,在HPL中还是可以听到PC播放的声音, 请问这个声音是从哪里来的呢? 图中的CM HP是什么,这个声音是不是从这里来的?具体配置如下: AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 12, 0x00 ); // LDAC AFIR routed to HPL AIC3204_rset( 13, 0x08 ); // RDAC AFIR routed to HPR |
hyqopen 发表于 2019-8-14 16:29 如果你听见的声音是很小的,是因为左右声道的串扰导致。确认另一个声道的声音没有开到很大。一般5mW是正常。你可以将DACLmute住这样也能证明声音不是从DAC进入。 |
qwe041 发表于 2019-8-14 16:36 现在这个旁路声音已经没有了, 我对比了一下之前的配置和现在的配置,DACL和DACR都是使用默认值,我主要是对时钟部分做了调整,把MADC和MADC,DOSR和AOSR调为不一样, void aic3204_init_different_mono(void) [ SYS_EXBUSSEL = 0x6100; // Enable I2C bus USBSTK5515_I2C_init( ); // Initialize I2C /* Configure AIC3204 */ AIC3204_rset( 0, 0x00 ); // Select page 0 AIC3204_rset( 1, 0x01 ); // Reset codec AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 1, 0x08 ); // Disable crude AVDD generation from DVDD AIC3204_rset( 2, 0x01 ); // Enable Analog Blocks, use LDO power AIC3204_rset( 10, 0x00 ); //#Set the input common mode to 0.9V AIC3204_rset( 61, 0x00 ); //#Set ADC PTM_R4 AIC3204_rset( 71, 0x00 ); //#Set MicPGA startup delay to 3.1ms AIC3204_rset( 123, 0x01 ); //#Set the REF charging time to 40ms /* PLL and Clocks config and Power Up */ AIC3204_rset( 0, 0 ); // Select page 0 AIC3204_rset( 27, 0x4d ); // BCLK and WCLK is set as o/p to AIC3204(Master) interface DSP AIC3204_rset( 28, 0x02 ); //#Data offset value ( ajout de 1 BCLK's) AIC3204_rset( 29, 0x08 ); //# Audio interface set AIC3204_rset( 61, 0x01 ); //ADC Signal Processing Block Control Register AIC3204_rset( 60, 0x8 ); //DAC Signal Processing Block Control Register AIC3204_rset( 4, 3 ); // PLL setting: PLLCLK <- MCLK, CODEC_CLKIN <-PLL CLK AIC3204_rset( 6, 8 ); // PLL setting: J=8 AIC3204_rset( 7, 0x07 ); // PLL setting: HI_BYTE(D=1680) AIC3204_rset( 8, 0x80 ); // PLL setting: LO_BYTE(D=1680) AIC3204_rset( 30, 0xc0 ); // For 32 bit clocks per frame in Master mode ONLY // BCLK=DAC_CLK/N =(12288000/8) = 1.536MHz = 32*fs AIC3204_rset( 5, 0x91 ); // PLL setting: Power up PLL, P=1 and R=1 AIC3204_rset( 13, 03 ); // Hi_Byte(DOSR) for DOSR = 768 decimal or 0x0300 DAC oversamppling AIC3204_rset( 14, 0x00 ); // Lo_Byte(DOSR) for DOSR = 768 decimal or 0x0300 AIC3204_rset( 20, 0x80 ); // AOSR for AOSR = 128 decimal or 0x80 for decimation filters 1 to 6 AIC3204_rset( 11, 0x88 ); // Power up NDAC and set NDAC value to 2 AIC3204_rset( 12, 0x82 ); // Power up MDAC and set MDAC value to 8 AIC3204_rset( 18, 0x88 ); // Power up NADC and set NADC value to 8 AIC3204_rset( 19, 0x8c ); // Power up MADC and set MADC value to 12 AIC3204_rset( 81, 0x00 ); // Power down Left and Right ADC AIC3204_rset( 63, 0x14 ); // Power down left,right data paths and set channel AIC3204_rset( 61, 2 ); // PRB_R2 // set biquad A to low pass fc = 3628 AIC3204_rset( 0, 8 ); // Select page 8 AIC3204_rset( 36, 0x6A ); // Left N0 H AIC3204_rset( 37, 0xC3 ); // Left N0 M AIC3204_rset( 38, 0x6F ); // Left N0 L AIC3204_rset( 40, 0x35 ); // Left N1 H AIC3204_rset( 41, 0x61 ); // Left N1 M AIC3204_rset( 42, 0xB7 ); // Left N1 L AIC3204_rset( 44, 0x00 ); // Left N2 H AIC3204_rset( 45, 0x00 ); // Left N2 M AIC3204_rset( 46, 0x00 ); // Left N2 L AIC3204_rset( 48, 0xD5 ); // Left D1 H AIC3204_rset( 49, 0x3C ); // Left D1 M AIC3204_rset( 50, 0x91 ); // Left D1 L AIC3204_rset( 52, 0x00 ); // Left D2 H AIC3204_rset( 53, 0x00 ); // Left D2 M AIC3204_rset( 54, 0x00 ); // Left D2 L AIC3204_rset( 0, 9 ); // Select page 9 AIC3204_rset( 44, 0x6F ); // Right N0 H AIC3204_rset( 45, 0x96 ); // Right N0 M AIC3204_rset( 46, 0x52 ); // Right N0 L AIC3204_rset( 48, 0x37 ); // Right N1 H AIC3204_rset( 49, 0xCB ); // Right N1 M AIC3204_rset( 50, 0x29 ); // Right N1 L AIC3204_rset( 52, 0x00 ); // Right N2 H AIC3204_rset( 53, 0x00 ); // Right N2 M AIC3204_rset( 54, 0x00 ); // Right N2 L AIC3204_rset( 56, 0xD0 ); // Right D1 H AIC3204_rset( 57, 0x69 ); // Right D1 M AIC3204_rset( 58, 0xAD ); // Right D1 L AIC3204_rset( 60, 0x00 ); // Right D2 H AIC3204_rset( 61, 0x00 ); // Right D2 M AIC3204_rset( 62, 0x00 ); // Right D2 L /* DAC ROUTING and Power Up */ AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 9, 0x30 ); //# OUTPUT DRIVER POWER CONTROL hp->ON lineout->OFF mixer->OFF AIC3204_rset( 10, 0x03 ); //#COMMON MODE CONTROL REGISTER Output of HP is powered by LDOIN AIC3204_rset( 11, 0x10 ); //Over Current detection is enabled for HPL & HPR AIC3204_rset( 12, 0x08 ); //# Left DAC (+) -> HPL AIC3204_rset( 13, 0x00 ); //# Left DAC (-) -> HPR AIC3204_rset( 14, 0x00 ); //# LOL is not routed AIC3204_rset( 15, 0x00 ); //# LOR is not routed AIC3204_rset( 16, 0x3c ); // HPL Driver gain setting register Unmute HPL , 0dB gain AIC3204_rset( 17, 0x3c ); // volume de sortie headphone 0x00 -> 0dB 0x3A -> -6dB 0x1d -> +29dB AIC3204_rset( 18, 0x40 ); //# LOL driver gain settings register AIC3204_rset( 19, 0x40 ); //# LOL & LOR MUTED AIC3204_rset( 20, 0x25 ); //#HEADPHONE DRIVER STARTUP Headphone amps power up slowly in 5.0 time constants / Headphone amps power up time is determined with 6K resistance AIC3204_rset( 22, 0x00 ); //# IN1L to HPL volume control bypass 0dB AIC3204_rset( 23, 0x00 ); //# IN1L to HPL volume control bypass 0dB AIC3204_rset( 24, 0x00 ); //# MIXERAMP Left volume control AIC3204_rset( 25, 0x00 ); AIC3204_rset( 51, 0x50 ); //# setting du micbias micbias = Vcc AIC3204_rset( 0, 0x00 ); // Select page 0 AIC3204_rset( 64, 0x00 ); //#DAC L UNMUTED, R&L independant DAC R MUTED (mode differentiel) //# 0x00 -> 0dB 0xFF -> -0.5dB 0x81 -> -63dB AIC3204_rset( 65, 0x00 ); //# Left DAC channel digital volume control register AIC3204_rset( 66, 0x00 ); //# Right DAC Channel Digital Volume Control Register AIC3204_rset( 63, 0x90 ); //#DAC L switched ON, R OFF, soft-stepping enabled /* ADC ROUTING and Power Up */ AIC3204_rset( 0, 1 ); // Select page 1 AIC3204_rset( 52, 0x30 ); //# IN2L -> Left MICPGA + 40K resistance AIC3204_rset( 54, 0x30 ); //# IN2R -> Left MICPGA - 40K resistance AIC3204_rset( 55, 0x00 ); //# Right MICPGA positive terminal input routing AIC3204_rset( 57, 0x00 ); //# Right MICPGA negative terminal input routing AIC3204_rset( 58, 0xbb ); //#Floating Input Configuration register AIC3204_rset( 59, 0 ); // MIC_PGA_L unmute AIC3204_rset( 60, 0 ); // MIC_PGA_R unmute AIC3204_rset( 0, 0 ); // Select page 0 AIC3204_rset( 81, 0x80 ); //#ADC right OFF & left ON AIC3204_rset( 82, 0x08 ); //#ADC left UNMUTED right MUTED AIC3204_rset( 83, 0x67 ); //#ADC left & right channel volume control AIC3204_rset( 84, 0x67 ); //#ADC volume 20dB -- 0x28 -12dB -- 0x67 AIC3204_rset( 85, 0x81 ); //#ADC phase adjust register AIC3204_rset( 0, 0 ); USBSTK5515_wait( 200 ); // Wait // I2S settings I2S0_SRGR = 0x0; //I2Sn Sample Rate Generator Register slave mode is invalide //I2S0_CR = 0x9011; // 16-bit word, slave, enable I2C Mono mode //I2S2_CR = 0x9e11; I2S0_CR = 0x8010; // I2S0_CR Address: 0x2800 ((I2S BUS) I2Sn Serializer Control Register (I2SSCTRL) // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // |15:14:13:12|11:10: 9: 8| 7: 6: 5: 4| 3: 2: 1: 0| <<== Bit Position // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // |rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw| <<== Read / Write Access // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // | 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| <<== Reset Values // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // | 1 0: 0: 1| 0: 1: 1: 0| 0: 0: 0: 1| 0: 0: 0: 1| <<== current Values // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // | | | | | | | | | | | | | | | | // | | | | | | | | | | | | | | | +-- [0] FRMT (0:I2S/left-justified format, 1:DSP format) // | | | | | | | | | | | | | | +----- [1] MODE (0:Serializer is configured as a slave, 1:master) // | | | | | | | | | | | | | +-------- [2] WDLNGTH (0:clk active, 1:clk disabled) // | | | | | | | | | | | | +----------- [3] WDLNGTH Choose serializer word length 8 10 .. 32 // | | | | | | | | | | | | // | | | | | | | | | | | +-------------- [4] WDLNGTH // | | | | | | | | | | +----------------- [5] WDLNGTH // | | | | | | | | | +-------------------- [6] SIGN_EXT (0:No sign extension, 1:Received data is sign extended. Transmit data is expected to be sign extended.For more information about sign extension) // | | | | | | | | +----------------------- [7] PACK (0:Data packing mode disabled, 1:Data packing mode enabled) // | | | | | | | | // | | | | | | | +-------------------------- [8] DATADLY (0:1-bit data delay, 1:2-bit data delay) // | | | | | | +----------------------------- [9] CLKPOL (0:Controls I2S clock polarity, 1:.....XXX $$$ ) // | | | | | +-------------------------------- [10] FSPOL (0:Inverts I2S frame-synchronization polarity, 1:....XXX $$$) // | | | | +----------------------------------- [11] LOOPBACK (0:Normal operation, no loopback, 1:Digital Loopback mode enabled) // | | | | // | | | +-------------------------------------- [12] MONO (0:Stereo mode, 1:Mono mode. Valid only when bit 0, FRMT=1 (DSP Format)) // | | +----------------------------------------- [13] Reserved // | +-------------------------------------------- [14] Reserved // +----------------------------------------------- [15] ENABLE (0:I2S disabled, 1:I2S enabled) //I2S0_ICMR = 0x17; // Enable interrupts I2S0_ICMR = 0x2b; // I2SINTMASK Address: 0x2814 ((I2S BUS) I2Sn Interrupt Mask Register (I2SINTMASK) // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // |15:14:13:12|11:10: 9: 8| 7: 6: 5: 4| 3: 2: 1: 0| <<== Bit Position // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // |rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw|rw:rw:rw:rw| <<== Read / Write Access // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // | 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 0| <<== Reset Values // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // +--+--+--+--+--+--+--+--+--+--+--+--+--+--:--:--+ // | 0: 0: 0: 0| 0: 0: 0: 0| 0: 0: 0: 1| 0: 1: 0: 0| <<== current Values // +--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+ // | | | | | | | | | | | | | | | | // | | | | | | | | | | | | | | | +-- [0] OUERR (0:Disable overrun/underrun error interrupt, 1:Enable overrun/underrun error interrupt.) // | | | | | | | | | | | | | | +----- [1] FERR (0:Disable frame-synchronization error interrupt, 1:Enable frame-synchronization error interrupt.) // | | | | | | | | | | | | | +-------- [2] RCVMON (0:Disable mono RX data interrupt, 1:Enable mono RX data interrupt.) // | | | | | | | | | | | | +----------- [3] RCVST (0:Disable stereo RX data interrupt, 1:Enable stereo RX data interrupt) // | | | | | | | | // | | | | | | | | | | | | // | | | | | | | | | | | +-------------- [4] XMITMON (0:Disable mono TX data interrupt, 1:Enable mono TX data interrupt) // | | | | | | | | | | +----------------- [5] XMITST (0:Disable stereo TX data interrupt, 1:Enable stereo TX data interrupt) // | | | | | | | | | +-------------------- [6] Reserved // | | | | | | | | +----------------------- [7] Reserved // | | | | | | | | // | | | | | | | +-------------------------- [8] Reserved // | | | | | | +----------------------------- [9] Reserved // | | | | | +-------------------------------- [10] Reserved // | | | | +----------------------------------- [11] Reserved // | | | | // | | | +-------------------------------------- [12] Reserved // | | +----------------------------------------- [13] Reserved // | +-------------------------------------------- [14] Reserved // +----------------------------------------------- [15] Reserved ] |
992 浏览 0 评论
612 浏览 1 评论
458 浏览 1 评论
649 浏览 2 评论
971 浏览 3 评论
240浏览 29评论
1206浏览 23评论
348浏览 20评论
322浏览 14评论
180浏览 13评论
GMT+8, 2025-2-23 11:37 , Processed in 0.966815 second(s), Total 47, Slave 41 queries .
