你好,我正在使用U2761A,我开发了一个C#.Net程序,它必须输出单发用户波形。
我尝试了很多方法,但它仍然不起作用。 有人可以解释一下如何用这个模块做单发波形吗? 我心里可以使用触发器使用的解决方案,但我不知道该怎么办! 在此先感谢。对不起我的英语 以上来自于谷歌翻译 以下为原文 Hello, I'm working with the U2761A, I developpe a C# .Net programs which have to output a single shot user waveform. I had try many ways but it still doesn't works. Can somebody explain me how to do a single shot waveform with this module? I heart that an solution with the trigger use can be used but I don't see how to do! Thanks in advance. ps: sorry for my English |
非常感谢您的回复,我将把模块更改为另一个模块。
我认为U2351A会做我想要的。 在文档中,他们说可以为用户定义的函数生成无数的itération。 你认为这是正确的模块吗? 该模块似乎与您提出的33220A相同。 但是33220A对我来说不是一个解决方案,因为模块必须嵌入已经设计了U2761A尺寸的盒子中。 以上来自于谷歌翻译 以下为原文 Thanks a lot for replies, I'm going to change the module to a another one. I think that the U2351A will do what I want. In the documentation they say that it's possible to generate un number of itération for a user-defined function. Do you think that 's the right module ? This module seems to do the same that the 33220A that you propose. But the 33220A cannot be a solution for me because the module have to be embedded in a box already designed with the dimension of the U2761A. |
嗨,不幸的是我认为这种仪器也不会起作用。
我不太熟悉这个产品,所以我采访了一些拥有这个设备的支持人员,这就是他们不得不说的。用户可以使用AO_Ext_Trig引脚打开模拟输出。 但是这个引脚不能产生高电压,低电流时最大仅为10V。 第二件事是,一旦触发,它将持续产生输出,直到用户停止它。 用户无法设置像FG那样允许突发控制的定时控制。 以上来自于谷歌翻译 以下为原文 hi, Unfortunately I don't think this instrument will work either. I am not too familiar with this product so I spoke to a few of the support guys that own this device and this is what they had to say. User can use the AO_Ext_Trig pin to turn on the Analog Output. But this pin can’t generate high voltage, max is only 10V at low current. Second thing is, once it trigger, it will continuously generate the output until user stop it. User can’t set the timing control like bench FG allowing the burst control. |
1030 浏览 0 评论
2276 浏览 1 评论
2063 浏览 1 评论
1933 浏览 5 评论
2806 浏览 3 评论
797浏览 1评论
582浏览 0评论
676浏览 0评论
2462浏览 0评论
1519浏览 0评论
GMT+8, 2024-9-20 11:41 , Processed in 1.119677 second(s), Total 47, Slave 42 queries .
