TLE9879QXA40是单片三相马达驱动器,集成了工业标准的32位ARM® Cortex® M3 核,工作频率高达40MHz,可以实现高档马达算法如磁场定向控制(FOC)等.器件包括六个全集成的NFET驱动器,通过六个外接功率NFET来驱动3相马达,一个可使低电压工作的电荷泵和具有电流斜率控制的可编电流,以优化EMC性能.它的外设包括电流传感器,逐次逼近ADC,它和捕获和比较单元同步,用于PWM控制和16位计时器.也集成了LIN收发器使的器件和大量的通用I/O进行通信.同时器件还包含线性电压稳压器,给外部负载供电.器件还集成了128KB闪存,4KB EEPROM,512B 100次可编存储器(100TP)以及6KB RAM,引导ROM用来起动固件和闪存程序.单电源工作5.5V-27V,可扩展电源至3V-28V,工作结温Tj = -40 °C 到+150 °C,和RoHS兼容,满足AEC规范.主要用在汽车马达控制.本文介绍了TLE9879QXA40主要特性,框图和应用框图,以及TLE9879 BLDC Arduino马达控制板主要特性,框图和简化应用框图,电路图,材料清单和PCB顶层布局图.
The TLE9879QXA40 is a single chip 3-Phase motor driver that integrates the industry standard ARM® Cortex® M3 core, enabling the implementation of advanced motor control algorithms such as field-oriented control.
It includes six fully integrated NFET drivers optimized to drive a 3-Phase motor via six external power NFETs, a charge pump enabling low voltage operation and programmable current along with current slope control for optimized EMC behavior. Its peripheral set includes a current sensor, a successive approximation ADC synchronized with the capture and compare unit for PWM control and 16-bit timers. A LIN transceiver is also
integrated to enable communication to the device along with a number of general purpose I/Os. It includes an on-chip linear voltage regulator to supply external loads.
It is a highly integrated automotive qualified device enabling cost and space efficient solutions for mechatronic BLDC motor drive applications such as pumps and fans.
TLE9879QXA40主要特性:
• 32 bit ARM Cortex M3 Core
– up to 40 MHz clock frequency
– one clock per machine cycle architecture
• On-chip memory
– 128 kByte Flash including
– 4 kByte EEPROM (emulated in Flash)
– 512 Byte 100 Time Programmable Memory (100TP)
– 6 kByte RAM
– Boot ROM for startup firmware and Flash routines
• On-chip OSC and PLL for clock generation
– PLL loss-of-lock detection
• MOSFET driver including charge pump
• 10 general-purpose I/O Ports (GPIO)
• 5 analog inputs, 10-bit A/D Converter (ADC1)
• 16-bit timers - GPT12, Timer 2, Timer 21 and Timer 3
• Capture/compare unit for PWM signal generation (CCU6)
• 2 full duplex serial interfaces (UART) with LIN support (for UART1 only)
• 2 synchronous serial channels (SSC)
• On-chip debug support via 2-wire SWD
• 1 LIN 2.2 transceiver
• 1 high voltage monitoring input
• Single power supply from 5.5 V to 27 V
• Extended power supply voltage range from 3 V to 28 V
• Low-dropout voltage regulators (LDO)
• High speed operational amplifier for motor current sensing via shunt
• 5 V voltage supply for external loads (e.g. Hall sensor)
• Core logic supply at 1.5 V
• Programmable window watchdog (WDT1) with independent on-chip clock source
• Power saving modes
– MCU slow-down Mode
– Sleep Mode
– Stop Mode
– Cyclic wake-up Sleep Mode
• Power-on and undervoltage/brownout reset generator
• Overtemperature protection
• Short circuit protection
• Loss of clock detection with fail safe mode entry for low system power consumption
• Temperature Range Tj = -40 °C to +150 °C
• Package VQFN-48 with LTI feature
• Green package (RoHS compliant)
• AEC qualified
图1. TLE9879QXA40框图
图2. TLE9879QXA40简化的应用框图
BLDC马达控制板
The BLDC Motor Control Shield with TLE9879QXA40 for Arduino Uno makes it easy to control and drive a BLDC motor. It features an Infineon TLE9879QXA40, a single chip 3-Phase motor driver with integrated MOSFETs.
The shield can be controlled by a microcontroller via an SPI interface - here the Arduino Uno R3 is used as master. Both the shield and the Arduino board are connected via the pin headers.
Up to four shields can be stacked via the pin headers, to control up to four BLDC motors
图3. TLE9879 BLDC Arduino马达控制板外形图
TLE9879 BLDC Arduino马达控制板主要特性:
• An Arduino Uno R3 connected to the shield can control a single chip 3-Phase motor driver via the SPI interface
• BLDC motor control
- 5.5 V - 28 V normal operating input voltage
- 28 V - 40 V extended operating input voltage
• Possibility to stack up to four shields
• SPI interface for high configurability and detailed diagnosis
• Protections:
- overtemperature
- overcurrent
- undervoltage
- overvoltage
• Motor speed control
图4. TLE9879 BLDC Arduino马达控制板简化应用框图
图5. TLE9879 BLDC Arduino马达控制板框图
图6. TLE9879 BLDC Arduino马达控制板元件放置图
图7. TLE9879 BLDC Arduino马达控制板电路图
TLE9879 BLDC Arduino马达控制板材料清单:
图8. TLE9879 BLDC Arduino马达控制板PCB设计图(顶层布局)
详情请见:
https://www.infineon.com/dgdl/In ... 733015a89d10a283f20 和
https://www.infineon.com/dgdl/In ... f120169a0bb25396e7d
Infineon-BLDC_shield-UM-v01_00-EN.pdf
Infineon-TLE9879QXA40-DS-v01_00-EN.pdf
