嗨,我正在开发VEE软件与SMU(源测量单元)接口,我需要在运行系统之前键入设置。
我创建了7种模式,每种模式都有不同的设置。 对于每种模式,我需要设置15个设置。对于这个方法,我理解我需要使用构建记录这15个设置我需要连接作为输入终端(构建记录1),单个输出将连接到另一个7输入buildrecord2,这将 是7种模式。 任何人都可以建议我如何将单个输出(构建记录1)切换到7个输入(Buildrecod2)。例如:当我想在模式1上设置设置时,输出(构建记录1)应该连接到模式1的输入 (构建记录2),接下来当我想设置mode2时,输出(buildrecod1)必须连接到mode2(构建记录2的输入)。谢谢,抱歉,如果我让你感到困惑 以上来自于谷歌翻译 以下为原文 Hi, I am developing VEE software to interface with SMU(Source Measure Unit), I need to key in the settings before i run the system. I create 7 modes, where each mode has different settings. For each mode i need to set 15 settings.For this method i understand i need to use Build record This 15 settings i need to connect as a input terminal to (build record1) and the single output will be connected to another 7 input buildrecord2 which will be 7 modes. Can any one advice me how to switch a single output (build record1) to 7 inputs(Buildrecod2). For example: When i want to set settings on mode 1, the output (build record1) should be connected to the input of mode 1(build record2), and next when i want to set mode2 the , the output(buildrecod1) will have to be connected to mode2 (input of build record2). Thanks and sorry if i am confusing you |
很难理解这个问题,因此给了一些帮助。一般来说,我建议用默认值初始化所有数据结构(记录)并存储在一个或多个变量中。
然后在配置等期间根据需要更新字段。 以上来自于谷歌翻译 以下为原文 Hard to understand the problem and therefore give some help. In general I would recommend to initialize all data structures (Records) with default values and store in one or more variables. Then it is easy to update fields as needed during configuration etc. |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1425浏览 1评论
827浏览 0评论
1195浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-24 17:30 , Processed in 1.666189 second(s), Total 77, Slave 61 queries .
