24C02读写操作程序.c #define uchar unsigned char #define uint unsigned int #i nclude #i nclude #i nclude ***it scl=P3^5; //24c02 SCL ***it sda=P3^4; //24c02 SDA ***it DOG=P1^7; //狗 uchar x24c02_read(uchar address); //从24c02的地址address中读取一个字节数据 void x24c02_write(uchar address,uchar info); //向24c02的address地址中写入一字节数据info void x24c02_init(); //24c02初始化子程序 void delay1(uchar x); void flash(); void x24c01_init();*PanJit* void start(); void stop(); void writex(uchar j); uchar readx(); void clock(); void delay1(uchar x) { uint i; for(i=0;i } void flash() { uchar u; DOG=~DOG; } void x24c02_init() { scl=1; flash(); sda=1; flash(); } void start() { sda=1; flash(); scl=1; flash(); sda=0; flash(); scl=0; flash(); } void stop() { sda=0; flash(); scl=1; flash(); sda=1; flash(); } void writex(uchar j) { uchar i,temp; temp=j; for (i=0;i<8;i++){ temp=temp<<1; scl=0; flash(); sda=CY; flash(); scl=1; flash(); } scl=0; flash(); sda=1; flash(); } uchar readx() { uchar i,j,k=0; scl=0; flash(); sda=1; for (i=0;i<8;i++){ flash(); scl=1; flash(); if (sda==1) j=1; else j=0; k=(k<<1)|j; scl=0; } flash(); return(k); } void clock() { uchar i=0; scl=1; flash(); while ((sda==1)&&(i<255))i++; scl=0; flash(); } uchar x24c02_read(uchar address) { uchar i; start(); writex(0xa0); clock(); writex(address); clock(); start(); writex(0xa1); clock(); i=readx(); stop(); delay1(10); return(i); } void x24c02_write(uchar address,uchar info) { EA=0; start(); writex(0xa0); clock(); writex(address); clock(); writex(info); clock(); stop(); EA=1; delay1(50); } |
AI模型部署边缘设备的奇妙之旅:边缘端设备的局域网视频流传输方案
1750 浏览 0 评论
1684 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:如何在边缘端部署OpenCV
6907 浏览 0 评论
tms320280021 adc采样波形,为什么adc采样频率上来波形就不好了?
1925 浏览 0 评论
5565 浏览 0 评论
80134 浏览 21 评论
GMT+8, 2025-3-5 05:45 , Processed in 0.587100 second(s), Total 71, Slave 55 queries .
