我安装了带有WaveGen选件的Agilent 2000示波器。
我用来测试ti的ADC模块,特别是它是ADS1278EVM模块。 我让WaveGen产生一个没有偏移电压的5VPP正弦波。 当我将示波器输入连接到wavegen输出时,我看到正弦波,但电压显示0.3VPP(约0.3V~,rms,我也安装了DVM选件)。 我看到这两个都是高z设置和50欧姆。 我将WaveGen接地连接到示波器接地。 这正是我通过我的ADC模块观察到的(我有一个FPGA,因为我的dsp连接到我的电脑)。 你能不能请问为什么我没有看到完整的5VPP? 以上来自于谷歌翻译 以下为原文 I have a Agilent 2000 oscilloscope with WaveGen option installed. I am using to test an ADC Module from TI, specifically it is ADS1278EVM module. I have the WaveGen generating a 5VPP sine wave with no offset voltage. When I connect my oscilloscope input to the wavegen output I see the sine wave but the voltage is showing 0.3VPP (about 0.3V~, rms, I also have the DVM Option installed). I see this both with high-z setting and 50ohm. I have the WaveGen ground connected with the oscilloscope ground. This is exactly what I observe through my ADC module as well (I have an fpga as my dsp connected to my computer). Can you please advice why am i not seeing the full 5VPP? |
5个回答
我认为你的WaveGen有问题。
我有一个3000系列,我将WaveGen输出直接连接到通道1.如果示波器设置为高Z,我看到5.27V pk-pk,如果示波器设置为50欧姆,我看到2.69V pk-pk 。 我不知道你的设备的输入阻抗是多少,但除非它是High-Z,你将永远不会看到5V pk-pk。 人 以上来自于谷歌翻译 以下为原文 I think that you have a problem with your WaveGen. I have a 3000 series, and I connected the WaveGen output directly to channel 1. I'm seeing 5.27V pk-pk if the scope is set to high-Z, and 2.69V pk-pk if the scope is set to 50 Ohm. I don't know what the input impedance of your device is, but unless it's High-Z, you won't ever see 5V pk-pk. Al |
发回它似乎是最好的选择,但您也可以尝试自我校准。
以上来自于谷歌翻译 以下为原文 Sending it back seems to be the best bet, but you could also try a Self-Calibration. |
是的,自校准是一种选择。 它使用WaveGen生成校准过程所需的各种波形,因此如果WaveGen出现问题,则校准将失败。 人 以上来自于谷歌翻译 以下为原文 Yes, self-calibration is an option. It uses WaveGen to generate the various waveforms necessary for the cal process, so if there is a problem with WaveGen, then the cal will fail. Al |
感谢您的帮助!
我刚刚将我的设备运回来进行更换。 他们也证实了这个问题。 以上来自于谷歌翻译 以下为原文 Thanks for all the help! I just shipped my unit back for replacement. They confirmed the problem as well. |
1317 浏览 0 评论
2389 浏览 1 评论
2207 浏览 1 评论
2079 浏览 5 评论
2963 浏览 3 评论
1194浏览 1评论
770浏览 0评论
992浏览 0评论
1317浏览 0评论
GMT+8, 2025-1-6 22:15 , Processed in 1.308920 second(s), Total 53, Slave 48 queries .
