自测错误(608)中的34970标记,将万用表板交换到另一个34970并通过自检,我怎样才能修复万用表板?
或者我应该检查点? 以上来自于谷歌翻译 以下为原文 34970 mark in a self test error (608), swap the multimeter board to the other 34970 and pass the self test, how I can repair the multimeter board ? or should I check points? |
很难说根本原因,它可能只是一个糟糕的连接,但这里有一个更详细的描述错误意味着什么:错误608 - 串行配置回读失败此测试重新发送last9字节串行配置数据到所有
串行路径。 然后将数据重新输入A1U209并与发送的原始9字节进行比较。 如果数据不匹配则发生故障。连接到DMM板的一些带状电缆出现问题,请参阅下面的服务说明,但如果是这样的话,我会期待其他错误消息和一些波动的读数.http: //cp.literature.agilent.com/litweb/pdf/34970A-14C.pdf 以上来自于谷歌翻译 以下为原文 It's hard to tell the root cause, it could just of been a poor connection but here is a more detailed description of what that error means: Error 608 - Serial configuration readback failed This test re-sends the last 9 byte serial configuration data to all the serial path. The data is then clocked back into A1U209 and compared against the original 9 bytes sent. A failure occurs if the data do not match. There was an issue with some of the ribbon cables connected to the DMM board, see service note below, but I would expect other error messages and some fluctuating readings if that was the case. http://cp.literature.agilent.com/litweb/pdf/34970A-14C.pdf |
1516 浏览 0 评论
2496 浏览 1 评论
2345 浏览 1 评论
2193 浏览 5 评论
3125 浏览 3 评论
1722浏览 1评论
929浏览 0评论
1517浏览 0评论
GMT+8, 2025-4-28 04:29 , Processed in 1.197229 second(s), Total 75, Slave 59 queries .
