void IMUupdate(float gx, float gy, float gz, float ax, float ay, float az, float mx, float my, float mz)
{ float norm; float hx, hy, hz, bx, bz; float wx, wy, wz; float vx, vy, vz; float ex, ey, ez; float q0q0 = q0*q0; float q0q1 = q0*q1; float q0q2 = q0*q2; float q0q3 = q0*q3; float q1q1 = q1*q1; float q1q2 = q1*q2; float q1q3 = q1*q3; float q2q2 = q2*q2; float q2q3 = q2*q3; float q3q3 = q3*q3; gx = gx*tog; gy = gy*tog; gz = gz*tog; ax = ax*toa; ay = ay*toa; az = az*toa; mx = mx*gua; my = my*gua; mz = mz*gua; if(ax*ay*az==0) return; if(cc==255&&dd==255&&ee==255) { imuupdate(val[0],val[1],val[2], val[3],val[4],val[5]); return; } norm = sqrt(ax*ax + ay*ay + az*az); //acc¹éÒ»»¯ ax = ax / norm; ay = ay / norm; az = az / norm; norm = sqrt(mx*mx + my*my + mz*mz); //mag¹éÒ»»¯ mx = mx / norm; my = my / norm; mz = mz / norm; hx = 2 * mx * (0.5 - q2q2 - q3q3) + 2 * my * (q1q2 - q0q3) + 2 * mz * (q1q3 + q0q2); hy = 2 * mx * (q1q2 + q0q3) + 2 * my * (0.5 - q1q1 - q3q3) + 2 * mz * (q2q3 - q0q1); hz = 2 * mx * (q1q3 - q0q2) + 2 * my * (q2q3 + q0q1) + 2 * mz * (0.5 - q1q1 -q2q2); bx = sqrt((hx*hx) + (hy*hy)); bz = hz; vx = 2*(q1q3 - q0q2); vy = 2*(q0q1 + q2q3); vz = q0q0 - q1q1 - q2q2 + q3q3 ; wx = 2 * bx * (0.5 - q2q2 - q3q3) + 2 * bz * (q1q3 - q0q2); wy = 2 * bx * (q1q2 - q0q3) + 2 * bz * (q0q1 + q2q3); wz = 2 * bx * (q0q2 + q1q3) + 2 * bz * (0.5 - q1q1 - q2q2); ex = (ay*vz - az*vy) + (my*wz - mz*wy); ey = (az*vx - ax*vz) + (mz*wx - mx*wz); ez = (ax*vy - ay*vx) + (mx*wy - my*wx); exInt = exInt + ex * Ki; eyInt = eyInt + ey * Ki; ezInt = ezInt + ez * Ki; gx = gx + Kp*ex + exInt; gy = gy + Kp*ey + eyInt; gz = gz + Kp*ez + ezInt; q0 = q0 + (-q1*gx - q2*gy - q3*gz)*halfT; q1 = q1 + (q0*gx + q2*gz - q3*gy)*halfT; q2 = q2 + (q0*gy - q1*gz + q3*gx)*halfT; q3 = q3 + (q0*gz + q1*gy - q2*gx)*halfT; norm = sqrt(q0*q0 + q1*q1 + q2*q2 + q3*q3); q0 = q0 / norm; q1 = q1 / norm; q2 = q2 / norm; q3 = q3 / norm; Yaww = atan2(2 * q1 * q2 + 2 * q0 * q3, -2 * q2*q2 - 2 * q3* q3 + 1)* 57.3; Pitchw = asin(-2 * q1 * q3 + 2 * q0* q2)* 57.3; Rollw = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1)* 57.3; } 六轴拟合算法程序,拟合后的数据yaw不偏移,但是上电以后初始角度不为0,为0的角度总是偏向于一个固定方位。这种现象正常吗?如果想为0,可以如何修改。 |
4个回答
偏航角肯定是会偏的吧。。。你又没有磁力计
是九轴拟合算法,不是六轴拟合算法。打错了。
不好意思,发错了,上面这个是 九轴算法,不是六轴算法。九轴数据出来以后偏航角不会偏移,但是初始位置不是0,我该如何调整。
259个成员聚集在这个小组
加入小组请问下图大疆lightbridge2遥控器主板电源芯片型号是什么?
4559 浏览 1 评论
使用常见的二极管、三极管和mos做MCU和模组的电平转换电路,但是模组和MCU无法正常通信,为什么?
434浏览 2评论
为了提高USIM卡电路的可靠性和稳定性,在电路设计中须注意的点有哪些?
451浏览 2评论
495浏览 2评论
464浏览 2评论
656浏览 2评论
GMT+8, 2025-3-7 15:59 , Processed in 1.138944 second(s), Total 83, Slave 67 queries .
