转换IC/转接芯片NCS8823:TYPE-C] **产品特点**:低功耗,高性能 TYPE-C 转换 **输出**:VGA **VGA输出**:VGA Output Compliant with VESA VSIS v1r2 R/G/B swappable 5V tolerance DDC I/Os **TYPE-C输入**:TYPE-C Input Specification Revision 1.3 compatible compatible Standard Version 1.0a compatible 1.62Gb/s or 2.7Gb/s link rate Refless clock system **其它**:Miscellaneous Embedded microcontroller **功率**:Power Power consumption ~TBD **封装**:Package RoHS Compliant
1786 浏览 0 评论
5645 浏览 0 评论
3236 浏览 2 评论
6233 浏览 2 评论
4120 浏览 0 评论
GMT+8, 2024-12-23 18:33 , Processed in 0.554190 second(s), Total 68, Slave 49 queries .
