扫一扫,分享给好友
Windows Phone 8.1中的Microsoft增加了新的NFC相关功能,包括低级访问(Non NDEF)。我有诺基亚Lumia 830(此设备中存在PN547 NFC芯片组)。我无法通过Lumia 830检测到Nfc标签(ANT-7M24LR-A,ISO15693),它可以使用Nfc-V进行读/写(ISO15693)在Android中。我还有一个Lumia 720(旧的NFC硬件)但至少它能够检测到标签。有没有人遇到过这个?什么是解决方法?
#m24lr #lumia 以上来自于谷歌翻译 以下为原文 Microsoft in Windows phone 8.1 has added new Nfc related features including low level access(Non NDEF). I have Nokia Lumia 830 (PN547 NFC chipset is present in this device).Im not able to detect Nfc tag (ANT-7M24LR-A ,ISO15693) through Lumia 830, which im able to read/write using Nfc-V(ISO15693) in Android. I also have a Lumia 720 (old NFC hardware) but atleast it is able to detect the tag. Has anyone encountered this ? Whats the workaround ? #m24lr #lumia |
好日子戈卡莱,
这是不正常的,在这个lumia上不允许使用ISO 15693。 (在新一代微软手机上,将支持ISO 15693) 您可以尝试使用M24SR-DISCO-PREM,它可以与Lumia NFC手机配合使用。 我希望这有帮助, 我祝福你有个美好的一天, ST NFC / RFID动态支持 以上来自于谷歌翻译 以下为原文 Good day Gokhale, This is unforunately normal, on this lumia the ISO 15693 is not allowed. (on the new generation of Microsoft phone, ISO 15693 will be supported) You can try to use M24SR-DISCO-PREM, that can be use with Lumia NFC enabled phone. I hope this is helping, I wish you a great day, ST NFC/RFID Dynamic support |
2703 浏览 1 评论
3233 浏览 1 评论
1804 浏览 1 评论
3641 浏览 6 评论
6027 浏览 21 评论
1329浏览 4评论
1384浏览 3评论
201浏览 3评论
191浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
339浏览 2评论
GMT+8, 2024-12-14 04:00 , Processed in 1.145053 second(s), Total 77, Slave 62 queries .
