你好,
我正在为Spartan 6设计一个不需要使用收发器的设计,但由于其他一些考虑因素,我仍在使用45T设备。 我应该怎么处理未使用的收发器组(101,123和一些专用信号)? 我在文档中找不到任何指导(为T设备支付额外费用然后不使用收发器是一件奇怪的事情,所以这是可以理解的!)。 任何有关正确方向的建议或要点都将不胜感激。 非常感谢您对此事的任何帮助。 以上来自于谷歌翻译 以下为原文 Hello, I'm drawing out a design for a Spartan 6 which does not require the use of transceivers but, owing to a number of other considerations, I'm still using a 45T device. What should I do with the unused Transcever banks (101, 123 and a few dedicated signals)? I can't find any guidance in the documentation (it's a strange thing to pay extra for a T device and then not use the transceivers, so this is understandable!). Any advice or points in the right direction would be greatly appreciated. Many thanks in advance for any assistance in this matter. |
Spartan-6 GTP用户指南的标题为“管理已使用和未使用的GTP收发器的电源连接”部分提供了您要查找的信息。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 The Spartan-6 GTP User Guide has a section titled "Managing Power Supply Connections for Used and Unused GTP Transceivers" that provides the information you are looking for.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
该文档包含有关未使用的Duals和Banks的信息,但是对于未使用的通道(TX / RX)对,在使用另一个通道的双通道中建议的连接是什么。
以上来自于谷歌翻译 以下为原文 The documentation has information about unused Duals and Banks, but what is the recommended connection for an unused lane (TX/RX) pair, in a dual where the other lane is used. |
2708 浏览 7 评论
3024 浏览 4 评论
2441 浏览 9 评论
3557 浏览 0 评论
2642 浏览 15 评论
3442浏览 1评论
852浏览 1评论
707浏览 1评论
GMT+8, 2025-7-19 09:24 , Processed in 1.311373 second(s), Total 77, Slave 61 queries .
