我已经安装了APWorkbench套件,但是在启动应用程序时我收到以下消息:'APWorkbench I / O警告:未找到FTDI驱动程序,APWLink通信将被禁用...... ..'。你能提供更多解释吗?
以上来自于谷歌翻译 以下为原文 I've installed the APWorkbench suite but I'm getting the following message when launching the application: 'APWorkbench I/O warning: No FTDI driver found, APWLink communication will be disabled…..'. Can you please provide more explanation about? |
5个回答
该
http://www.st.com/web/en/catalog/tools/PF253187 用于与Sound Terminal评估套件通信,并要求第三方驱动程序正常运行。驱动程序可从http://www.ftdichip.com/Drivers/D2XX.htm获得 。 虽然FTDI驱动程序已包含在APWorkbench安装程序包中,但只有在实际的APWLink I / F通过USB连接到PC后才能完成安装。如果不发生这种情况,将禁用与此类I / F的通信。 请注意,APWorkbench仍然可以在仿真模式下运行(不与任何实际IC /设备通信)或通过http://www.st.com/web/en/catalog/tools/PF258331运行 , 如果可供使用的话。此外,建议使用STAudioHub接口进行ST MEMS麦克风评估。 以上来自于谷歌翻译 以下为原文 The http://www.st.com/web/en/catalog/tools/PF253187 is used to communicate with Sound Terminal evaluation kits and requires a third-party driver to operate correctly. Driver is available from http://www.ftdichip.com/Drivers/D2XX.htm . Though FTDI driver is already included in the APWorkbench setup package its installation will be completed only once an actual APWLink I/F is connected to the PC, via USB. If this does not happen the communication with such I/F will be disabled. Note that APWorkbench can still be operated either in simulation mode (no communication with any actual IC/device) or through an http://www.st.com/web/en/catalog/tools/PF258331 , if available. Also, STAudioHub interface is recommended for ST MEMS Microphone evaluation. |
取决于你的窗户你可能需要手动安装驱动程序,即使Windows认为驱动程序是好的,那么apworkbench将找不到它们
以上来自于谷歌翻译 以下为原文 depends on your windows you maybe have to install the drivers manually, even if windows thinks the drivers are okay then apworkbench will not find them |
嗨,
我遇到了与FTDI驱动程序相同的问题。 那方面有运气吗? 谢谢, 乔纳森 以上来自于谷歌翻译 以下为原文 Hi, I'm experiencing the same issue with the FTDI drivers. Any luck on that front? Thank you, Jonathan |
我已经使用APworkbench(64)在Win7(64)下手动安装了驱动程序,但仍未找到。
关于下一步做什么的任何建议? 以上来自于谷歌翻译 以下为原文 I have installed the drivers manually under Win7(64) with APworkbench(64), still not found. Any suggestion on what to do next? |
乔纳森,
确保从FTDI站点下载并安装适用于您的操作系统(64位)的驱动程序版本。 此外,仅在将实际的STAudioHub板插入USB端口后才能完成驱动程序安装。 马尔科 以上来自于谷歌翻译 以下为原文 Jonathan, Make sure to download and install the proper driver version for your OS (64 bits) from the FTDI site. Also, the driver installation will be completed only after an actual STAudioHub board will be plugged on the USB port. Marco |
2875 浏览 1 评论
3281 浏览 1 评论
1861 浏览 1 评论
3707 浏览 6 评论
6117 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
353浏览 2评论
GMT+8, 2025-2-23 04:48 , Processed in 1.163244 second(s), Total 82, Slave 66 queries .
