我想知道STL62P3LLH6 P沟道MOSFET的安全工作区图表是否正确
http://www.st.com/web/en/resourc ... heet/DM00105886.pdf 。我一直在比较各种其他部分的这些图表,特别是VDS = 20V时的ID值和100ms脉冲宽度。此部分在此位置显示~20A的ID。但是,在PowerFLAT软件包(或类似软件包)中,我没有发现任何其他值很高的部件。具有如此高值的所有其他部件是DPAK(或类似的,具有低约3倍的热阻),并且相当昂贵(> 4x)。我想问一下这是一个数据表错误还是一个非常好的交易。如果我在阅读数据表时出错,请告诉我。谢谢! 以上来自于谷歌翻译 以下为原文 I'd like to know if the STL62P3LLH6 P-channel MOSFET's Safe Operating Area chart is correct in http://www.st.com/web/en/resourc ... heet/DM00105886.pdf . I have been comparing these charts of various other parts, specifically the ID value at VDS = 20V and a 100ms pulse width. This part shows an ID of ~20A at this location. However, I've found no other parts with a value this high in a PowerFLAT package (or similar). All other parts with a value this high are DPAK (or similar, with a ~3x lower thermal resistance), and are quite a bit more expensive (>4x). I'd like to ask if this is a datasheet mistake or a very good deal. If I'm making a mistake reading the datasheet please let me know. Thanks! |
你好,
对不起,这款功率MOSFET不属于信号调理产品。 我建议您联系/ onlinesupport / app?page = onlineSupport 另一种可能性是将您的问题发布在https://my.st.com//public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards/AllItems.aspx 对不起,这个重定向。 问候, 西尔 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello, I'm sorry but this power MOSFET is not part of signal condiioning products. I recommended you to contact the /onlinesupport/app?page=onlineSupport Another possibility would be to post your question in https://my.st.com//public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards/AllItems.aspx Sorry for this redirection. Regards, Sylvain Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
2841 浏览 1 评论
3274 浏览 1 评论
1852 浏览 1 评论
3698 浏览 6 评论
6111 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
401浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
493浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
322浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
240浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
344浏览 2评论
GMT+8, 2025-2-9 13:00 , Processed in 0.978007 second(s), Total 47, Slave 41 queries .
