我使用bq25700 给7.4v的电池充电,设置充电电压是8.4 v ,充满电后还在继续充,电压是8.6v了,请问是哪里设置需要注意下?
3 个讨论
Hi
确认一下你设置的终止充电电压,注意先写 REG0x15() 再写g REG0x14() 。注意如下: (可以用示波器看一下这个电压) The SRN pin is used to sense the battery voltage for voltage regulation and should be connected as close to the battery as possible, and directly place a decoupling capacitor (0.1 µF recommended) as close to the device as possible to decouple high frequency noise |
341 浏览 1 评论
539 浏览 2 评论
781 浏览 3 评论
655 浏览 1 评论
1138 浏览 1 评论
69浏览 29评论
201浏览 23评论
256浏览 20评论
205浏览 14评论
65浏览 13评论
GMT+8, 2024-12-25 01:21 , Processed in 1.100288 second(s), Total 70, Slave 56 queries .
