你好
我完成了一个使用SPIx1进行MultiBoot的设计(只有比特流A和B没有Goldenstream)。 结果是我的期待。 然后我用SPIx4读命令(03-> 6B)修改ICAP inpout并在BitGen中设置spi宽度。 上电时,比特流A正常,当重启striger输入时,比特流B无法正常启动。 谢谢 以上来自于谷歌翻译 以下为原文 hello I had complete a design that using SPIx1 for MultiBoot(just bitstream A and B without Goldenstream). and the result was as my espect. And then I modify the ICAP inpout with SPIx4 read command(03->6B) and set the spi width in BitGen. when power up, bitstream A is ok and when a reboot striger input, bitstream B was not boot right. Thanks |
6个回答
@byedzsqDid你为SPIX4 .bit文件重新生成.mcs?
-Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @byedzsq Did you regenerate .mcs for SPIX4 .bit files? -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
感谢您的回复。
我设置ICAP输入用命令6b设置比特流A和B.并在BitGen中设置spi总线宽度A和B生成位文件然后使用IMPACT重新生成.mcs文件 以上来自于谷歌翻译 以下为原文 thank you for reply. I set the ICAP input is set with command 6b both bitstream A and B. and set the spi bus width in the BitGen both A and B generate bit file then use IMPACT regenerate the .mcs file |
你在用spartan-6设备吗?
检查以下链接 http://www.xilinx.com/support/answers/41156.html 以上来自于谷歌翻译 以下为原文 are you using spartan-6 device? check the following link http://www.xilinx.com/support/answers/41156.html |
嗨,谢谢你。
我之前找到了这个链接,并且在我的设计中没有后退,我很困惑那个步骤是nessasery。 以上来自于谷歌翻译 以下为原文 hi, thank you. I had find this link before and thers is no fallback in my design and I'm puzaled that which step is nessasery . |
当您使用-g SPI_buswidth:4开关时,bitgen会将多引脚头添加到生成的文件中(可能因为它是向FPGA声明SPI四读指令的唯一方法)。
通用寄存器中的所有地址默认为0x000000,因此如果跳转到第二个设计,则会读取多重引导头,将地址设置回0x000000并发出IPROG - 并且第一个设计加载。 你怎么能避免这种情况? - 您可以将每个设计都视为“黄金”,并使用您需要的地址填写所有-g next_config_addr等,以便每个比特流都获得它自己的completemultiboot-header。 - 您可以使用-g SPI_buswidth:1并使用ICAP声明SPI四读指令 - 或者您可以使用-g SPI_buswidth:4并记住多引导头长度为0x44字节,并调整您的地址以跳过标头。 以上来自于谷歌翻译 以下为原文 When you use the -g SPI_buswidth:4 switch, bitgen will add the multiboot-header to the generated files (maybe because it is the only way to declare the SPI quad-read instruction to the FPGA). All the addresses in the GENERAL registers are defaulted to 0x000000, so if you jump to you second design, the multiboot-header is read, the address is set back to 0x000000 and an IPROG is issued - and your first design loads. How can you avoid this? - You can treat every design as "golden" and fill out all the -g next_config_addr etc. with the address you need, so that every bitstream gets it own complete multiboot-header. - You can use -g SPI_buswidth:1 and declare the SPI quad-read instruction with your ICAP - Or you can just use -g SPI_buswidth:4 and keep in mind that the multiboot header is 0x44 bytes long and adapt your addresses to jump over the header. |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2444浏览 1评论
658浏览 1评论
519浏览 1评论
2074浏览 0评论
800浏览 0评论
GMT+8, 2025-2-23 23:47 , Processed in 1.390709 second(s), Total 86, Slave 70 queries .
