我今天用遥控来控制定时器2中TH1,TL1的初值,结果会导致遥控器发送的值在单片机中读取会乱码,只有把TH1,TL1的值确定了之后遥控器才不会乱码。这让我觉得很奇怪,不明白为什么会这样子,如果只是用按键来控制TH1,TL0的值,那不会有问题。
请各位大神帮帮忙,以下是我的代码。 #include #include"1602.h" #include"delay.h"#define uchar unsigned char #define uint unsigned int ***it IR=P3^2; //红外接口标志 ***it key=P2^0; ***it led=P3^7; ***it Dj_Cp1=P1^0; uchar int_num; char code Tab[16]="0123456789ABCDEF"; /*------------------------------------------------ 全局变量声明 ------------------------------------------------*/ unsigned char irtime=0;//红外用全局变量 bit irpro_ok,irok; unsigned char IRcord[4]; unsigned char irdata[33]; unsigned char TempData[16];#define speed1 5000 uint speed=5000; //频率 uint adj_speed; //档数 /*------------------------------------------------ 函数声明 ------------------------------------------------*/ void EX0init(void); void TIMinit(void);//定时器0初始化void Ir_work(void); void Ircordpro(void); /*------------------------------------------------ 主函数 ------------------------------------------------*/ void main(void) { DJ_Init(); TIMinit(); //初始化定时器 EX0init(); //初始化外部中断 LCD_Init(); //初始化液晶 DelayMs(20); //延时有助于稳定 LCD_Clear(); //清屏 LCD_Write_String(0,0,"www.doflye.net"); LCD_Write_String(0,1,"Code:"); while(1)//主循环 { if(irok) //如果接收好了进行红外处理 { Ircordpro(); irok=0; } if(irpro_ok) //如果处理好后进行工作处理,如按对应的按键后显示对应的数字等 { Ir_work(); switch(IRcord[3]) { //调频 case 246: adj_speed=adj_speed+1; if(adj_speed==10) adj_speed=9; break; case 234: adj_speed=adj_speed-1; if(adj_speed==0) adj_speed = 1;break; default: break; } switch(adj_speed) { case 1: speed = 5000; break; //100HZ case 2: speed = 3333; break; //150HZ case 3: speed = 2500; break; //200HZ case 4: speed = 2000; break; //250HZ case 5: speed = 1666; break; //300HZ case 6: speed = 1429; break; //350HZ case 7: speed = 1250; break; //400HZ case 8: speed = 1111; break; //450HZ case 9: speed = 1000; break; //500HZ default: break; } } } } /*------------------------------------------------ 定时器0中断处理 ------------------------------------------------*/void tim0_isr (void) interrupt 1 using 1 { irtime++; //用于计数2个下降沿之间的时间 }/*------------------------------------------------ 外部中断0中断处理 ------------------------------------------------*/ void EX0_ISR (void) interrupt 0 //外部中断0服务函数 { static unsigned char i; //接收红外信号处理 static bit startflag; //是否开始处理标志位if(startflag) { if(irtime<63&&irtime>=33)//引导码 TC9012的头码,9ms+4.5ms i=0; irdata=irtime;//存储每个电平的持续时间,用于以后判断是0还是1 irtime=0; i++; if(i==33) { irok=1; i=0; } } else { irtime=0; startflag=1; } }/*------------------------------------------------ 定时器1中断服务子程序 ------------------------------------------------*/ void int2_serive(void) interrupt 3 { TH1=(65536-speed)/256; TL1=(65536-speed)%256; int_num++; if(int_num==1) { Dj_Cp1=1; }else { Dj_Cp1=0; int_num = 0; } }/*------------------------------------------------ 定时器初始化 ------------------------------------------------*/ void TIMinit(void)//定时器初始化 { TMOD=0x12;//定时器0工作方式2,TH0是重装值,TL0是初值,定时器1工作方式1 TH0=0x00; //重载值 TL0=0x00; //初始化值 TH1=(65536-speed)/256; TL1=(65536-speed)%256; ET0=1; //开中断0 ET1=1; TR1=0; //定时器T1允许中断 TR0=1; } /*------------------------------------------------ 外部中断0初始化 ------------------------------------------------*/ void EX0init(void) { IT0 = 1; //指定外部中断0下降沿触发,INT0 (P3.2) EX0 = 1; //使能外部中断 EA = 1; //开总中断 } /*------------------------------------------------ 键值处理 ------------------------------------------------*/void Ir_work(void) { TempData[0] = Tab[IRcord[0]/16]; //处理客户码 TempData[1] = Tab[IRcord[0]%16]; TempData[2] = '-'; TempData[3] = Tab[IRcord[1]/16]; //处理客户码 TempData[4] = Tab[IRcord[1]%16]; TempData[5] = '-'; TempData[6] = Tab[IRcord[2]/16]; //处理数据码 TempData[7] = Tab[IRcord[2]%16]; TempData[8] = '-'; TempData[9] = Tab[IRcord[3]/16]; //处理数据反码 TempData[10] = Tab[IRcord[3]%16]; LCD_Write_String(5,1,TempData); irpro_ok=0;//处理完成标志 } /*------------------------------------------------ 红外码值处理 ------------------------------------------------*/ void Ircordpro(void)//红外码值处理函数 { unsigned char i, j, k; unsigned char cord,value; k=1; for(i=0;i<4;i++) //处理4个字节 { for(j=1;j<=8;j++) //处理1个字节8位 { cord=irdata[k]; if(cord>7)//大于某值为1,这个和晶振有绝对关系,这里使用12M计算,此值可以有一定误差 value|=0x80; if(j<8) { value>>=1; } k++; } IRcord=value; value=0; } irpro_ok=1;//处理完毕标志位置1 } |
帮顶....
3366 浏览 0 评论
3370 浏览 9 评论
3063 浏览 16 评论
3553 浏览 1 评论
9186 浏览 16 评论
1305浏览 3评论
671浏览 2评论
666浏览 2评论
2411浏览 2评论
1978浏览 2评论
GMT+8, 2025-2-24 23:01 , Processed in 0.878726 second(s), Total 76, Slave 57 queries .
