大家好,
我正在使用ST NFC芯片:M24LR16E在我的产品中,我发现一些与市场上的智能手机不兼容(三星S4,S5,Nexus 4) 我做了一些研究,发现这些手机使用的Broadcom NFC芯片(BC20794)与产品中的某些NFC芯片不兼容。这取决于所使用的NFC标签的类型。 (大多数现有产品都有Mifare Classic 1k标签,它只与恩智浦芯片配备的手机兼容)。 事实上,M24LR16E具有ISO15693标准,与智能手机的NXP NFC芯片(PN544,PN65N ......)的标准相同。而Broadcom芯片中的ISO标准是ISO 18092,ISO14443(来自NFC论坛1-4类标签)...... 所以问题来自于这种不同类型的NFC标签威廉希尔官方网站 (Mifare Classic 1k vs NFC Forum Type 1-4)?或者它来自应用程序? 有人有同样的问题吗?我们需要更换M24LR16E芯片吗? 谢谢您的回答 问候 #nfc #compatible #mifare#iso15693#m24lr16e#m24sr#m24lr #nfc 以上来自于谷歌翻译 以下为原文 Hi all, I am using a ST NFC chip : M24LR16E in my products and I noticed some incompatibility with Smartphones of the market (Samsung S4, S5, Nexus 4) I have made some research and I found that these phones were using a Broadcom NFC chip (BC20794) which is not compatible with some NFC chips in the product. It depends on the type of NFC tag used. (Most of existing products has Mifare Classic 1k tag and it is just compatible with NXP chip equiped phones). In fact the M24LR16E has ISO15693 standard, which is the same standard as in the NXP NFC chips of the Smartphones (PN544, PN65N...). Whereas the ISO standards in the Broadcom chips are ISO 18092, ISO14443 (from NFC Forum type 1-4 tags)... So the problems comes from this different type of NFC tags technology (Mifare Classic 1k vs NFC Forum Type 1-4)? Or is it coming from the application? Do someone has the same problems? Do we need to change the M24LR16E chips? Thank you for your answers Regards #nfc #compatible #mifare #iso15693 #m24lr16e #m24sr #m24lr #nfc |
对不起,我正在尝试获取M24LR04E标签的温度。如何通过CR95HF DLL获取当前温度?
以上来自于谷歌翻译 以下为原文 Sorry,i am trying to get the temperature of M24LR04E tag. How can i get the current temperature via CR95HFDLL? |
嗨,
我想您正在使用M24LR-Discovery,并希望通过RF路径读取温度值(显示在LCD屏幕上)。遗憾的是,温度值未通过固件存储在M24LR04E中,因此无法通过RF读取。温度值由微控制器直接读取并显示在屏幕上。为了能够通过RF读取温度,您应该修改固件代码,以便通过微控制器读取温度,然后在M24LR04E中写入温度值。在此修改之后,温度值将通过RF提供。 这是M24LR-Discovery STM8L微控制器的源代码: http://www.st.com/web/en/catalog/tools/PF258104 要通过CR95HF读取M24LR04E,可以使用M24LR_Application_Software。 http://www.st.com/web/en/catalog/tools/PF257516 最好的祝福, NFC / RFID ST支持 以上来自于谷歌翻译 以下为原文 Hi, I suppose you are using M24LR-Discovery and want to read the temperature value (displayed on LCD screen) with RF path. Unfortunately, the temperature value is not stored in the M24LR04E by the firmware and so, cannot be read by RF. The temperature value is directly read and displayed at screen by the microcontroler. To be able to read temperature through RF, you should modify the firmware code in order to read the temperature via microcontroler , then write temperature value in the M24LR04E. After this modifications, the temperature value will be available via RF. This is source code of the M24LR-Discovery STM8L microcontroler: http://www.st.com/web/en/catalog/tools/PF258104 To read M24LR04E through CR95HF, you can use M24LR_Application_Software . http://www.st.com/web/en/catalog/tools/PF257516 Best regards, NFC/RFID ST support |
2985 浏览 1 评论
3313 浏览 1 评论
1894 浏览 1 评论
3747 浏览 6 评论
6162 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
54浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
59浏览 5评论
92浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
58浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
55浏览 5评论
GMT+8, 2025-4-5 05:45 , Processed in 0.764133 second(s), Total 79, Slave 63 queries .
