我有Agilent 5747A电源,我喜欢在电流源模式下操作。
我的问题是除了设置电流限制之外如何将其设置为当前模式,因此如果电流超限,它将翻转到CC。 如果有人能给我建议,我会很感激。谢谢,tuan 以上来自于谷歌翻译 以下为原文 I have Agilent 5747A power supply and I like to operate it in current source mode. My question is how to set it in current mode besides setting current limit so it will flip to CC if the current is overlimit. I'd appreciate if anyone can give me advices. thanks, tuan |
你好Tuan,你负载将确定该单位是否处于CV或CC模式。
您可以在电源上设置两个参数,电压和电流限制。 电源将始终保持CV,直到达到电流限制,然后转到CC(始终遵循欧姆定律)。 例如,假设我们有一个1欧姆的负载:情况1Vset = 1 V且I设置= 2 A.在这种情况下,该单元将处于1 V的CV,源为1 A.情况2VSet = 5 VI set = 2 A. 根据欧姆定律,电压设置为5 V,电流应为5 A.我们的电流限制仅为2 A,因此该单元将在2 V的CC输出2 A。让我知道这是否对您有意义。 马特 以上来自于谷歌翻译 以下为原文 Hi Tuan, You load is going to determine if the unit is in CV or CC mode. You set two parameters on the power supply, the voltage and a current limit. The power supply will always stay in CV until it hits the current limit and then go to CC (always following Ohm's law). For instance assume that we have a 1 Ohm load: Case 1 Vset = 1 V and I set = 2 A. In this case, the unit will be in CV at 1 V sourcing 1 A. Case 2 VSet = 5 V I set = 2 A. By Ohm's Law, with a voltage setting of 5 V, the current should be 5 A. Our current limit is only 2 A so the unit will be in CC sourcing 2 A at 2 V. Let me know if this makes sense to you. Matt |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3020 浏览 3 评论
1431浏览 1评论
827浏览 0评论
1198浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-25 09:13 , Processed in 1.282750 second(s), Total 77, Slave 61 queries .
